Subwoofer box
Arsenall11
Maple Valley Wa
24 Ranger Raptor
Mechanical contractor
how does the Kicker keyloc integrate into the system? I do not have a factory sub on my 24 XLT.
No go then, it intercepts the signal from the head unit. Easy way to do it is tap the rear speakers for a signal. Old school but it works.
DirtDerrick
Nathan
Atlanta
dirtderrick.com
People Person
How did you tie it in with factory system? Did you just disconnect the factory sub and run the wires to new sub?
i had a car audio shop do it. They're better at it than I am. They put in all new speakers,amps, and sound deadening. I did remove the factory sub.
jorosz0309
Minneapolis
Just an FYI the JL 10TW1 does not fit in the Australian Stealt-tech box. The subwoofer is too deep and will cause the entire box to not fit. Ask me how I know lol
SHOOT!!! #&*$^% I remember reading this a long time ago but forgot about it. Now I have the Aussie box being delivered tomorrow and have a JL 10TW1-2 on order also. Do you recall about how close it was to fitting? That TW-1 is pretty shallow mount - most of the excursion is in the box rather than above the mount - hence the extra depth. But I'm just curious whether an MDF ring could be added to get the mounting depth up high enough. If not I suppose I'll need to go with the Hertz. Which sub did you use?
jorosz0309
Minneapolis
I went ahead and edited my order from the TW1 to the TW3. On the ebay page for the aussie stealthbox it appears someone else was able to use the TW3. Seems the Hertz and TW3 both need larger volumes than the TW1, but it also appears they're both still performing well. We'll see I guess!
https://www.ebay.com/itm/192610319641
Hofstetm
Mitch
Wisconsin
2024 Ford Raptor Ranger, 2022 Tesla Model X Plaid
I have the JL Stealthbox with the TW1. Other than the physical dimensions what’s the difference between the TW1 and TW3? More RMS watts needed for the TW3 I believe - but does that come with a wider (deeper) frequency range too?
jorosz0309
Minneapolis
Yeah apparently the TW1 doesn’t fit in the standalone Aussie stealth box like it does in the JL stealth box so I went with the TW3. The 3 wants a bit more box volume and in that volume would have higher Xmas and lower F3 (40hz vs 45 for TW1) but it likely won’t dig that deep with such a small volume box. The TW3 also has dual voice coils.
I’m sure it’ll be light years better than that factory 5” and I’ll probably have to keep it pretty low given the output of these subs anyway. We’ll see how the install goes. Just debating on whether to remove the factory sub or leave it in to fill out the mid-bass. Probably leave it in, see if there are any phasing issues, and maybe unplug later if it doesn’t sound great.
