- Joined
- Sep 7, 2023
- Threads
- 11
- Messages
- 245
- Reaction score
- 270
- Location
- Pennsylvania
- Vehicle(s)
- 2025 Ranger Lariat 2.7
- Thread starter
- #1
I just installed a set of Nokian Outpost nAT tires on a set of Method 703 rims with +35mm offset. The tires are 255/75r17 which are about 32” (32.1”?) and same width as the original tires. The nokian’s diameter is 1” taller than the stock 255/65r18.
No clearance issues yet and I don’t anticipate having any problems. I did not lift the truck or add spacers or do anything at all to the suspension or anything.
The truck came from the factory with Goodyear wrangler territory at (not at/s like the 2024’s I saw had). The Nokians are slightly louder than the stock Goodyears, though they’re also less inflated (30lbs) than the Goodyears were (35lbs). Both the Goodyears and the nokians are the same width, but the Methods are 8.5” vs the stock rim’s 7.5 so I expected a bit more stiffness from the Nokian/method combo. I haven’t noticed a difference yet so maybe the stiffness increase was offset by the nokians being slightly taller? I dunno…
