Amber Lights for top of Ranger Raptor grille?
Same, looking forward to seeing how this new option looks once installed.
RANGER/HOBB
THE WORLD
Retired USAF
You’re welcome!
I’m waiting on mine, they pulled back the order to provide some other items for me. Delivery on the 14th as it shows.
Thanks for the feed back. Good to hear.
I was planning on utilizing the primary hook up for the same purpose.
I figured they’d have a leg up on getting fitment right, after having the Ranger Raptor for a few years.👍🇺🇸
Ag3ntC00p3r
Product Manager
I went back and forth and decided to use Aux 1. For no other reason than giving me the flexibility to turn off.
Thanks again Ranger/Hobb for the tip on the source.
They definitely look better than the eBay specials I got. Appear to be less hot-spotty plus I already have LED failures on mine.
FullSend
Ninjaneer
Yea I was not exactly thrilled with that answer but sounds like they not planning to make the lights for us as a ready to plug and play perfect fit many of us were really hoping for.
On the bright side I guess for me, I already bought there F150/Ranger Gen 3 lights and installed the lights on my RR.
So, all I will need to do is follow their instructions once they come out with them, or hopefully an instruction video as to how make the lights I have fit better. I am willing to give that try.
I just got mine from F150Leds and maybe I misinterpreted the 'sticking out' with them actually sitting in front of the grill slot, because mine do not insert at all. So not sure if I was sent the wrong kit. I will definitely be returning, they look terrible.
Peter949
Peter
Irvine, CA
Can you take a picture? I was planning to purchase from them.
Yea, they think they fit I guess because some of us made them fit.
I had to pull the double sided foam tape off, then jam/wedge them in there as far as I could get them then zip tied the wire harness in tight on the back side of the grill, that wire harness and zip Ike’s are all thats holding mine in Place. Not really ideal.
Ford Ranger Amber Lights for top of Ranger Raptor grille? IMG_9013
Ford Ranger Amber Lights for top of Ranger Raptor grille? IMG_9014
Ford Ranger Amber Lights for top of Ranger Raptor grille? IMG_9016
Ford Ranger Amber Lights for top of Ranger Raptor grille? IMG_9017
FullSend
Ninjaneer
They do not insert at all. Photo of test fit, but I also did flip it and tried the actual side. They are not tapered so doesn't matter, was trying to make sure the wire wasn't keeping it from pushing in. Confident the bit of red tape covering the adhesive is not the culprit. These clearly are not made specifically for the Ranger and should not be advertised as so. Disappointing considering the premium price. Hopefully they will cover the return shipping due to their false advertising.
Ford Ranger Amber Lights for top of Ranger Raptor grille? PXL_20240915_190622651
Peter949
Peter
Irvine, CA
Thanks, a lot! I'll wait for a revision. Was about to pull the trigger soon.
FullSend
Ninjaneer
Ah I see now. Thanks for sharing how you forced them to fit in. They really shouldn't be advertising these as Ranger specific.
Yea, I tried my best to relay to them that they do not really fit the Ranger Raptor well at all, and thought they were going to come out with a light that does fit, that is until, there latest video, and I questioned them on it, they more or or less said they fit. That others have installed them, well I am one of those others and would certainly never tell anyone they fit well, or fit properly, they have to be customized to make them fit really well.
Nore: With the install video it is not on a Ranger Raptor .
FullSend
Ninjaneer
I think I may order these here soon. Did you do the single color? The dual amber / white version are a unique design but not sure I like them enough to burn both Aux 1/2 for them.
Might pull the trigger on the Bi-LED Projector Fog Lights Upgrade along with them.
GLW
Missouri
I think I made a mistake not getting the duel color set especially since I’m not planning on adding anymore lights or gadgets needing an aux switch.
On the other hand I really can’t see using the white light either. I like the amber a lot.
The duel set is a little bigger which may look even better in the holes. IF, they fit as nice as the single color.
