US Raptor Best Oil Catch Can?
Salty
Cyprus
Ranger raptor V6
Hey fellas, this goes out to the experienced. Would you recommend the single or dual valve option CC? Does the dual valve require any mods to the intake pipes? Completely inexperienced in this topic. Thanks
ag02m5
Google
I chatted with a guy from the place I posted the deal. Here is his input.
"So the Dual valve is basically a suction line ad that helps draw it out. It is kind of the best of the best but it is pretty overkill for a stock daily driver yeah. If you start dabbling in ethanol and tuning and things like turbo upgrades and stuff down the road it's a good thing to have but definitely overkill for what's on the market right now as a rule."
He also thought single is fine for stage 1 type stuff like a tune. Guess I can swap it out if I ever decide to make poor decisions and over mod it.
I think the dual valve does require a hole in intake pipe but don't quote me.
HyperM3
Alex
Lawrenceville, NJ
Yes, you do need to drill a hole in the intake pipe for the dual valve model. The install instructions for both models are on the UPR page and easy to read prior to ordering.
dguffin
Dana
Aberdeen, SD
24 Ranger Raptor,23 Aviator,19 Bullitt,08 Zuma
Shop Foreman
Wish I would of kept reading further down and got the discount code. Already ordered.
Ag3ntC00p3r
Wisconsin
Product Manager
With the truck being new and under warranty I went with single can so it can be easily removed before dealer service.
HyperM3
Alex
Lawrenceville, NJ
wlarsen76
Wells
Wisconsin
Yea. I ordered the dual and then realized too late that it required drilling. I sent an email to UPR to see if they'll let me swap it back out for the single. It's within 30 days, so maybe I'll just have to pay for shipping.
Slyder
Washington
KTM 1290R, '24 Ranger Raptor
Machinist
I wasn't paying attention when I ordered mine and got the dual.
It's essentially the same as the single with the exception of that is has another hole tapped into the top for the clean intake elbow.
I just bought a 5 pack of stainless steel 1/4 npt hex plugs, put some orange permatex thread sealant on a plug and installed the plug.
No leaks and it works like the single and I also have the option of going to the dual later on, if I wish to do so.
wlarsen76
Wells
Wisconsin
Oh, that's a great idea!! Where did you get the plugs?
Slyder
Washington
Machinist
wlarsen76
Wells
Wisconsin
I just received a response from UPR with another great idea.
UPR Products Sales<sales@uprproducts.com> said:
You can cap the un used fitting for the WOT hose by removing it and installing a 1/4NPT fitting, or just use a rubber vacuum cap over the un used fitting. There isn't any pressure at that fitting.
If you try to remove the fitting from the catch can, there is a good chance you will damage it.
I may just purchase these rubber vacuum caps from Amazon.
raf1919
Chicago
IT
New RR owner here. Any chance of another group buy??
rocsteady
New Jersey
Federal LEO
Everyone happy with their UPR purchase so far? I've always had J&L oil seperators on previous vehicles and seemed to be a great product. Thus far they don't show one for the Ranger Raptor though. Wouldn't it be the same for the Bronco Raptor? J&L does list one for that.
Catalyst
Justin
Bend, OR USA
Network Engineer
Yes, UPR is working well and quality similar to J&L I’ve had on other vehicles.
Blue_Raptor
Simi Valley, CA
I am still using mine and mostly happy with it. I installed the full dual valve version, which plumbs a line to the intake tube that feeds the passenger side turbo. Once I receive the replacement intake tube I will be removing that line and having it configured as just the standard single valve. It is my understanding that the stock PCV system closes off when under boost, so it seems having that extra line to evacuate the can under boost is not really gaining anything. I'll also check the can for oil volume while I'm doing that.
