There are some here seemingly adamantly in favor of the use of catch cans, saying that if you simply require proof that you are nothing more than a contrarian Luddite.
Catch cans are certainly worthy of consideration. Consideration requires examination of the evidence.
A subject which cannot withstand scrutiny is by definition , no longer worthy of consideration.
To anyone reading this, I say use a catch can if you choose but at least consider all sides before doing so.
Here (for your consideration) is an entertaining and balanced video which presents a broader view of the issue and yet leaves the decision where it belongs... In the hands of the owner...
Some of the YouTube comments are quite good too...There are some here seemingly adamantly..........
Earlier this year, I installed a catch can on my 2019 Mazda Miata from a well established and respected after market company. Kt cost me about $200. Six months and 4000 miles later, I removed the catch can from the Miata for several reasons - (1) the original hoses used were apparently not compatible with the oil-fuel crankcase blow-by resulting in a strong smell both in the car and when parked in the garage. NOTE: they did later come out with a replacement nitrile hose to address this issue (2) the catch can has a 50 micron porous bronze filter in the outlet port and I have a concern of a potential to restrict the flow of pressure from the crankcase if not cleaned regularly.There are some here seemingly adamantly in favor of the use of catch cans, saying that if you simply require proof that you are nothing more than a contrarian Luddite.
The only way I would change my thinking on a catch can for the 2.3L EcoBoost in my Ranger is if either:
1. Ford releases a TSB to retrofit a catch can to the engine after incorporating same in production
2. or the after market company pays Ford Engineering to review the catch can installation and provide a No Technical Objection /NTO/ which is NOT an approval statement - just a cursory review stating they don't see any obvious negative impact to the engine
My guess is both above 1 and 2 will never happen........
You make a persuasive point but....The manufacturer is only concerned about your vehicle making it out of the warranty period, without having to paying out on warranty claims. As long as their still reaching that goal, they're not going to peruse further preventative measures. So, 1 and 2 are guaranteed not to happen![]()
ford sells millions ,yes millions of Eco boost in different forms. you are on point with your reply . I worry about FRAME rust here in CT way more than intake valve carbon.step on the gas now and then from day one an you will be fine. Drive like a Oldman for short trips any engine is going to get carbon build up and clogged cats and rotted mufflers!!You make a persuasive point but....
Do you remember GM's V8 and V6 diesels from the early eighties? They would easily outlast the warranty , but not much more and not without attention. They were so poor that they practically destroyed GM's light truck/car diesel program for a generation.
Reliability reputation is very important, and Ford has put a LOT of its eggs into the EcoBoost basket!
They may add MPFI in combination with DI if they see problems, but for now I think they like the advanced PCV system they have as a solution. Time will tell.
This is also a good point. I believe Ford and others do try to achieve better than just getting past the warranty period, because reputation is important. But they still face cost and other competitive pressures that may limit what preventative measures they can add. My understanding is that they have either reintroduced PFI in the larger EB engines, or maybe they always had it. If that's true, I don't think they incurred the extra cost of that just to eliminate/reduce valve deposits. I read that it helps meet emissions under certain operating conditions. Maybe the 2.3 EB doesn't benefit from that. Toyota has also been reintroducing PFI in some engines as well.You make a persuasive point but....
Despite having installed a catch can on our Ranger, this is the first anti-catch-can argument that I agree with.Earlier this year, I installed a catch can on my 2019 Mazda Miata from a well established and respected after market company. Kt cost me about $200. Six months and 4000 miles later, I removed the catch can from the Miata for several reasons - (1) the original hoses used were apparently not compatible with the oil-fuel crankcase blow-by resulting in a strong smell both in the car and when parked in the garage. NOTE: they did later come out with a replacement nitrile hose to address this issue (2) the catch can has a 50 micron porous bronze filter in the outlet port and I have a concern of a potential to restrict the flow of pressure from the crankcase if not cleaned regularly.
Not sure how much in-service testing some of the after market companies actually do, i.e., length of time. I'm sure Mazda Engineering does extensive testing before committing to a design feature. My engineering background is in aviation. Typically we do a failure "what if analysis" on designs. A catch can impacts the most expensive component on a vehicle. I question if many companies in the after market do this. If the engine is damaged as a result of an after market installation, will or can the company financially support warranty costs.
I come from small diesels, which have a water separator in the fuel system. The manufacturers figured out a while ago how to turn that into an item to be serviced in the scheduled maintenance interval, and I'm sure they could do the same with a catch can if there was value in doing so.If catch cans came pre-installed on cars my feeling is that since it is a maintenance type item most people on the road will never ever check them for service. Which would eventually cause problems when they fill up.
