mtesni
CT
24 Ranger Raptor, 23 Bronco Badlands
Tossed on a new set of wheels and tires today. RTR Evo 6 Satin Charcoal Wheels (17x9 +30) and Goodyear Territory MT 315/70-17 Tires.
The total setup ended up being substantially lighter than the factory wheels and tires. The wheels averaged out to 22.3 lbs, tires 53.5 lbs. Mounted and balanced weight was 76.6lbs compared to the stock non beadlocks at 85.2lbs.
I ended up needing to remove the front crash bars for not to get them to fit, would rub on them on a level surface. I would not recommend running something this large without a lift in the front, I have a Foutz 2.5" collar on the way, but it will work for a few days of on road driving.
Ford Ranger New (Lighter) Shoes for the Raptor: RTR Evo 6 Satin Charcoal Wheels (17x9 +30) and Goodyear Territory MT 315/70-17 Tires PXL_20240525_194435596
Ford Ranger New (Lighter) Shoes for the Raptor: RTR Evo 6 Satin Charcoal Wheels (17x9 +30) and Goodyear Territory MT 315/70-17 Tires PXL_20240525_155635438
Ford Ranger New (Lighter) Shoes for the Raptor: RTR Evo 6 Satin Charcoal Wheels (17x9 +30) and Goodyear Territory MT 315/70-17 Tires PXL_20240525_164007032
davidfigs
This is really interesting, thanks for posting. I'm curious to see the fitment once you get the 2.5" collars
Looks great!
Nice to see more +30 options.
‘I need to remove my front crash bars at some point.
‘Did you have any trouble getting them off?
mtesni
mtesni
CT
The front crash bars weren't too bad to remove. The 2x plastic pins screw out to remove the plastic trim piece on crash bar itself. Then there are 2x 15mm bolts that thread in from the top (the nuts are welded on the bottom) a ratcheting wrench was able to fit between the bar and the fender liner to remove them. A little additional clearance was needed to slide them out so I removed the plastic trim from the inside corner of the bumper that's held on by 2x T30 and 1x 10mm bolts. Not sure it was needed but I also removed the large IP40 bolt holding the bumper to its mount to allow a little flexibility to pull the bumper up and forward while pulling the crash bar rearward and down.
I looked at removing the rear bars but that seems impossible without either cutting the bar or removing a body panel. There is not enough room to directly slide them out.
Also, this new wheel tire combo fits in the factory spare tire location. The mount slides through the and supports the wheel as intended and even fully inflated the tire JUST fits. I might deflate it for a little piece of mind as I have a compressor coming so inflating wouldn't be an issue.
Ford Ranger New (Lighter) Shoes for the Raptor: RTR Evo 6 Satin Charcoal Wheels (17x9 +30) and Goodyear Territory MT 315/70-17 Tires PXL_20240528_135057107
v8 goat
North Texas
Nice! I have the same set of wheels and tires in my garage for my Cactus Gray. I have an appointment to get them installed on Wednesday of this coming week. Did you get the Foutz collars installed yet?
I did the 1.5” collars already, and I am hoping this setup will fit without having to remove the crash bars.
I’m curious what my weight savings will be - I have the beadlocks, and I think those weigh a bit more. Did you notice any positive effects from the weight savings?
nikhsub1
Los Angeles
2018 Raptor
So then nothing needs to be cut to remove the front crash bars? They just unbolt and slide out?
Crapblaster
2025 F150 Spave White Platinum, 2024 HPR Ranger Raptor
How does it ride now? The broncos with those tires ride pretty well.
mtesni
mtesni
CT
Yes, I was able to slide the front's out without cutting anything at all. I plan to reinstall them after I get the perch collars
They ride great, very similar to the KO3's, maybe a little more road noise.
Do they poke at all?
They sit pretty close to even with the top of the flare. Slightest pit of poke maybe, I'll add a few more pictures.
mtesni
mtesni
CT
I saw you post, looks great!! Haven't had a chance to get the collars on yet. Not sure about you but I'm not seeing any negative changes to power or MPG. I have over 1500 miles on them already and so far so good!
derichio02
Bo
Southern California
Bronco Raptor, Maverick Hybrid, Ranger Raptor
Im seriously considering RTR Wheels after having them on my Bronco.
Are you rubbing or did you have to remove the rear crash bar? Any pics of how close it is in the rear? I really want to keep my Rokblokz mudflaps lol.
Also did you level yet? I was thinking of a 2” collar would be good to hear from someone with a 2.5”
PONTOY
Paul
California
please share your update with the 1.5 perch collar🙏🏼
i have ordered my 2.25” collar from rpg. Curious what the 1.5” look and clearance it provide.
Ford Motor Company
Official Ford Account
Ford
Dearborn, MI
Ford Ranger
The wheels and tires look great on your Raptor, Matt 🔥. We hope you've been enjoying your truck!
mtesni
mtesni
CT
I installed Foutz 2.5" Collars in the front and 2.0" in the rear. I was able to leave the rear crash bars in place so far, I haven't been able to completely flex everything out to confirm full articulation clearance but for regular driving and fast unimproved roads I have not had any contact.
Before the Collars
Ford Ranger New (Lighter) Shoes for the Raptor: RTR Evo 6 Satin Charcoal Wheels (17x9 +30) and Goodyear Territory MT 315/70-17 Tires PXL_20240525_194435596 (1)
After:
Ford Ranger New (Lighter) Shoes for the Raptor: RTR Evo 6 Satin Charcoal Wheels (17x9 +30) and Goodyear Territory MT 315/70-17 Tires PXL_20240615_223347910
Picked up just about 2.5" in the front and just under 2" in the rear.
