jbethune
NC
2024 2.7 Ranger XLT
Updated with official TSB fix posted by @BriSco
TECHNICAL SERVICE BULLETIN
Extra Effort Required To Close Hood With A “Hood Ajar” Warning Indicator
24-2233
29 July 2024​
Model:
Ford
2024 Ranger
Markets: North American Markets Only
Issue: Some 2024 Ranger vehicles may exhibit a hood that requires extra effort to engage the primary latch when closing the hood. This may be due to the misalignment of the latch assembly to the hood striker. This condition does not affect the secondary latch operation and the hood will remain secured. To correct this concern, follow the Service Procedure to adjust the latch and adjust the bump stop rubbers.
Action: Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria:
• 2024 Ranger
• Difficult to latch hood
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Service Part Warranty (SPW)/Service Part New Vehicle (SPNV)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/SPW/SPNV/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
DescriptionOperation No.Time
2024 Ranger: Adjust The Bump Stop Rubbers Retest Includes Time To Remove The Radiator Sight Shield And Adjust The Hood Latch If Necessary (Do Not Use With Any Other Labor Operations)
242233A​
0.3 Hrs.​
Additional Time To Adjust Panel Gaps (Can Be Claimed With Operation A)
MT242233​
Actual Time​
Repair/Claim Coding
Causal Part:16700
Condition Code:01
Service Procedure
1. Open the hood.
2. Adjust the bump stop rubbers located on the hood assembly by turning the bump stop rubbers clockwise until the bump stop rubber is fully wound in to the hood inner panel.
3. Once the bump stop rubbers are wound in all the way, turn the bump stop rubbers counter clockwise 3.25 turns.
4. Open the hood and hold it 12-13 inches (304-330 mm) above the latch and drop the hood. Did the hood latch easily?
(1). Yes - repair is complete.
(2). No - proceed to Step 5.
5. Remove the radiator sight shield. Refer to WSM, Section 501-14.
6. Loosen the latch attachment bolts (Figure 3) and align the latch so it is centered to the hood striker. (Figures 1-2)
Figure 1
Ford Ranger Hood Latch Fix! [Official TSB Fix Added] {filename}
Figure 2
Figure 3
7. Open the hood and hold it 12-13 inches (304-330 mm) above the latch and drop the hood. Did the hood latch easily?
(2). No - proceed to Step 8.
8. Adjust the bump stop rubbers located on the hood assembly counter-clockwise 0.5 turns.
9. After adjustments are made, closely inspect for even panel gaps between the hood, fenders, and grille and align as necessary. Refer to WSM, Section 501-03.
I just adjusted the rubber bump stops up half a turn now it's as smooth as butter. No more slamming it/dropping it from 2 feet up. Now it's just 3-4 inches.
jbethune
NC
2024 2.7 Ranger XLT
Nice! Mine was sitting too low in the fender wells…bump stops up prob wouldn’t help…also as mentioned in the video I have no real idea what I’m doing
NASSTY
ME
Mine too. I had to move my latch up about 3/16".
BriSco
'24 Ranger XLT, 2.7L V6
For the money I paid for this truck, I'm not going to work on things that Ford should have got right the first time. That being said, there is a service bulletin on the hood latch issue.
24-2233
29 July 2024​
Model:
Ford
2024 Ranger
• 2024 Ranger
Labor Times
242233A​
0.3 Hrs.​
MT242233​
Actual Time​
Repair/Claim Coding
Causal Part:16700
Condition Code:01
Service Procedure
1. Open the hood.
Figure 1
Figure 2
Figure 3
DesertBumAZ
AZ
24 RaRaptor
InfoSec
For the money I paid for this truck, I'm not going to work on things that Ford should have got right the first time. That being said, there is a service bulleting on the hood latch issue.
24-2233
29 July 2024​
Model:
Ford
2024 Ranger
Labor Times
242233A​
0.3 Hrs.​
MT242233​
Actual Time​
Repair/Claim Coding
Causal Part:16700
Condition Code:01
Service Procedure
1. Open the hood.
Figure 1
Figure 2
Figure 3
Thank you, ill mess with mine tomorrow. I get the sentiment but if i take it to the dealership it will turn into a 2+ hour ordeal.
engel762
2024 Ford Ranger Lariat
When I got my Ranger at the end of July the hood was hard to shut, even more so after I installed hood struts and a bug guard. Quick adjustment of the latch and bumpers fixed it and it closes very easily now.
wlarsen76
Wells
Same. I just followed the video. That was super easy. Done in 10 minutes -- That includes hunting my tools down and putting them away.
PawnX
PNW
Ranger
By just adjusting the bump stops as described mine now latches way better than it did.
I wish I'd saw this service note sooner since I just had it in for the auto window rollup issue last week and just had then do everything then. Still shuts a little harder than it should.
Snkrjeff020
Boulder, Colorado
Medical Scientist
Did anyone find that after performing hood latch fix, it also fixed uneven gaps between the hood and fender?
RANGER/HOBB
THE WORLD
Retired USAF
Nope one side is still closer than the other.🫵👍🇺🇸
jbethune
NC
2024 2.7 Ranger XLT
You can shift the latch over to correct uneven gaps
Snkrjeff020
Boulder, Colorado
Medical Scientist
My truck is currently at Ford right now and I am literally having to show them this TSB. They originally wouldn't fix the hood latch cause they said the panels were misaligned and had to go to a body shop.
I am trying to get them to follow this TSB first.
miniR
NC USA
I adjusted mine today after watching the helpful video posted by jbethune….thanks!
It was a 30 minute task, as I took my time. I adjusted the rubber bump stops first, then the latch. The hood now closes with firm pressure, or by dropping it from 8-10 inches, way different than dropping it from a couple feet.
In addition, the hood is now perfectly aligned with the fenders. I’m so glad I did this myself rather than taking it to the service department.
I just adjusted the bump stops and 3-4 inches drop it closes.
