- Joined
- Feb 27, 2025
- Threads
- 8
- Messages
- 227
- Reaction score
- 203
- Location
- United States
- Vehicle(s)
- 2024 Ranger Raptor
- Occupation
- Electrical Engineer
- Thread starter
- #1
Understanding Engine Break In | Dos and Don'ts
Great video that provides some insight into the "why" which explains the recommendations in Ford's owner's manual. My Mazda 3 and CX-9 owner's manuals also mirrored the recommendations in Ford's for my 11/24 RR.
I followed the manual's instructions as much as possible for the 3 and RR, but my wife's CX-9 already had 2,300 miles on it when I got it, so not much choice on that one other than hope the dealer (was a demo car, 9k below sticker) didn't do anything outside of those recommendations.
2024 Ranger Owner's Manual
As per the service manual linked above, the only information provided in the service manual which has been posted in other threads is the following:
"Breaking-In
You need to break in new tires for approximately 300 mi (480 km). During this time, your vehicle may exhibit some unusual driving characteristics.
Avoid driving too fast during the first 1,000 mi (1,600 km). Vary your speed frequently and change up through the gears early. Do not labor the engine.
Do not tow during the first 1,000 mi (1,600 km)."
Most of us generally try to follow the recommendations, but there is often much debate as to the "why". I think hearing from engine development engineers provides some significant credibility behind the "why" and that's the purpose of this post, which is knowledge transfer (educational).
Summary of Do's and Don'ts During Break-in
1. Do not tow to avoid sustained high loads at constant RPM.
2. Try to vary the engine RPM across the range mid-range frequently during the breaking process (i.e., back country roads with periodic stop signs / stop lights, merging onto highways at moderate throttle, down-shifting frequently on the highway etc.).
3. Avoid any sustained high RPM / Wide Open Throttle operation (highway pulls, drag racing etc.) to avoid excessive thermal loading during break-in.
4. Do not run the engine at very low rpm at high loads (lugging) due to decreased oil film strength at lower RPMs, which can adversely affect break-in by causing localized heating on the bearing surfaces during mixed mode and boundary layer lubrication regimes where a partial oil film forms (rotational velocity, surface area and temperature dependent).
"Breaking-In
