Symphony RGB Interior Kit
coolsp2
uSA
2204 Ranger
I recently bought the symphony 20 in 1 RGB interior kit similar to the ambient lighting for the BMWs. Should I document my install since no one has attempted to do anything related to this. I have already installed and tested the kit on one of the door panels and it looks ungodly. I can’t tell the reliability of the strips because they’re from Ali Express but other than that it’s so cool.
coolsp2
uSA
2204 Ranger
The aft two doors require a constant 12V power wire which is unavailable. The window switch as well as the speaker do not supply a constant 12V, so I am going to run a wire from the left side drivers fuse panel routed through the left and behind the seats over to the right side aft door panel. I am going to use this wire for both the left aft and right aft door symphony kits. I have already installed the kit on all 4 doors, however only the front two have power currently. If anyone finds a better way to use the aft door switch and speaker wire for power please let me know. Once I run the wire, I will make a video showing how I did it and how I installed the front symphony kit as well. I am also awaiting more parts from the same seller on Ali express. I needed an extension harness for the kit along with an extra strip for the center console, will try to get the video out next month if I get everything sorted out. But here’s a peak on how it looks like inside front.
Here is the kit I ordered, 22 in 1. All of them on Ali express seem to be the same but this one has a lot of reviews and ratings from a reputable seller. The quality is still cheap, I had to resolder one of the connection points from the storage light unit because I pulled too hard, but was easy to do.
I just found this on AliExpress: $51.26 | 14 in 1 18 in 1 64 Color RGB Symphony Car Atmosphere Interior LED Acrylic Guide Fiber Optic Universal Decoration Ambient Lights
https://a.aliexpress.com/_msjrlq3
