Retrax tonneau cover for 2024 Ford Ranger 2024 global market
jrRaptor
Maize, KS
I plan to send an email out with pics, comments, and questions. Going to register it tomorrow.
jvunc
Jacques
NOUMEA
Ford Ranger NextGen Wildtrak 2023
Network Manager
thanks for update.
jvunc
Jacques
NOUMEA
Network Manager
thanks for update
jvunc
Jacques
NOUMEA
Network Manager
Thanks, I'll send them pictures and see what they say. These have 4 additional bracket and the rails sit on top making them sit a bit proud, hence wht they stick up like that. I'll ask, maybe, hopefully I just installed incorrectly. The instruction manual isn't great and videos don't include the version with the additional brackets for the 2024 Ranger.
Sure thing. Here are some pictures. It almost seems like if the seal was a bit longer and maybe thicker, it would work ok. I think the problem is the slight step in the tailgate increases the distance from the seal.
What is the lenght size of retraxpro XR side rail ?
is it longer than external cargo size?
jrRaptor
Maize, KS
Ford Ranger Retrax tonneau cover for 2024 Ford Ranger 2024 global market 20240512_203625_resized
Ford Ranger Retrax tonneau cover for 2024 Ford Ranger 2024 global market 20240512_203639_resized
Ford Ranger Retrax tonneau cover for 2024 Ford Ranger 2024 global market 20240512_203651_resized
Another thing I noticed today, the drain hoses do not lock in place. Instructions say to put into drain hole and rotate and they'll lock. They don't. I lost one of the tubes today. Instead of drilling a hole in the bed plugs, I just took the plugs out and routed the hoses through the open plug holes. Bad idea lol.
Hawkpilot10
Maine
Ranger Raptor 2024, Bronco 2021 Bronco two door Wildtrak
Retired Helicopter Pilot
I prefer my new Tesser direct from Greece via UPS.
Ford Ranger Retrax tonneau cover for 2024 Ford Ranger 2024 global market IMG_0830
Ford Ranger Retrax tonneau cover for 2024 Ford Ranger 2024 global market IMG_7843
jvunc
Jacques
NOUMEA
Network Manager
It seems that the side rail fit now correctly to tailgate compared to first pictures, and no gap anymore.
does rain get wet inside?
It seems that the side rail fit now correctly to tailgate compared to first pictures (where the side rail extend beyond the body) and no gap anymore where rain can flow.
Ford Ranger Retrax tonneau cover for 2024 Ford Ranger 2024 global market 1715575908014-88
Ford Ranger Retrax tonneau cover for 2024 Ford Ranger 2024 global market 1715576099238-4u
did you push more side rail on front box ?
does rain get wet inside now regarding your last pictures ?
jvunc
Jacques
NOUMEA
Network Manager
RetraxPro XR support T-slot bars (Yakima, thule) which can be slide from tailgate and can be removed easily at anytime when needed. this is be big difference compared to others.
it depend on what is your need.
jrRaptor
Maize, KS
No change actually, that's just the angle of the photo. If I did push the rails further towards the tailgate, the seal might work there but then there would be a gap at the cab side, plus the rails would be sticking out ridiculously far over the end. I think the biggest culprit is the step at the edge of the tailgate. If that wasn't there it might seal better, but not perfect. As for rain intrusion, it's actually not bad so far, some water inside but not soaking wet. Granted I haven't driven much in the rain yet so that may be a difference. With car washes, there's a lot of water intrusion but it's pressured water pushing through any crevice and the biggest gaps are the sides of the tailgate.
Hawkpilot10
Maine
No updates or photos?
No Truck yet! Ford has given me three 45 day emails saying no scheduled date on my order yet…..Grrrrr
GLW
Missouri
I have the same top and the same problem. I’m thinking of adding this to the trim to give it a little more depth.
Ford Ranger Retrax tonneau cover for 2024 Ford Ranger 2024 global market 1717762439615-o3
dt75
john
california
2024 Rnager XLT
Did you end up adding this rubber edge trim to your cover?
CherryCoke
Las Vegas
Drinking CherryCoke
I bought mine from Ford and had to return it. I got my money back 3 months later. Now I'll go back and order it again.
Maybe 🤔
Why return? Boxes came all damaged, taped multiple times and rear brackets were missing. 🤷‍♂️
