Poll: Stock or Pro Cal (What's your experience, Good, Bad, Meh?)
Still mulling over the Pro Cal and looking for a good collection of feedback from everyone's experiences with it. Some say it's the best thing for the RR since filling up with premium...some say it's not worth the price of admission...some say stock for long term reliability concerns or the ability to run 87 for more frequent use cases. Lots of varying opinions, just looking for a variety of feedback.
Summary of What We Know / Things to Consider
1. We now know the 10R60 is rated for 600 lb-ft of input torque. With the factory output maximum of 430 lb-ft, there's a 29% safety margine which is close to a 2/3 de-rating for high reliability. The Pro Cal does cut that margine down to about 10% but certainly does NOT exceed the input torque rating.
Also, the 600 lb-ft input torque rating is the maximum input torque the 10R60 can handle and still achieve its rated service life (150k-200k which is typical of OE life span expectations). So, while it does reduce the safety margin, how meaningful that will be long term is debatable (if it has any significant impact at all remains to be seen).
2. We also know that Ford Performance has their 3yr/36k supplemental warranty to cover any damage IF it was found the Pro Cal caused it. Beyond that you're relying on the factory / extended warranties after that point and they are still valid for any failures NOT deemed to be caused by Pro Cal (i.e., a cam phasor goes out, which I think is unlikely to be deemed to be caused by the Pro Cal given the history of that issue). There is increased risk, but it's low.
3. Requires 91 or higher octane. The added power / torque is coming from eliminating the need for the ECU to scale back timing if the driver suddenly switches from 91 back down to 87. You can only get so aggressive of 91 when having to scale back timing advance fast enough in that event.
4. The Pro Cal does NOT affect towing as directly stated by Ford Performance.
5. Ford Performance also states they extensively tested BOTH the engine and driveline for durability, so despite cutting the safety margine down from 29% to 10%, it is still well tested none the less.
6. Requires install by ASE certified tech for warranty. Levittown has it for about $685, so add in labor of around $150, it's not terribly expensive.
What's your personal experiences with the Pro Cal vs. stock? Looking for details, specific things you like or dislike to really consider whether to go Pro Cal or stay stock. I've used FP products in the past as my 2016 GT PP had a Stage 2 Power Pack, but not all of FP's Cal's are worth it (some are very modest and just not worth the price, while others provide substantial enhancements).
boraxman
Santa Clarita, Ca. USA
Bought my truck in December and kept it stock until about a month ago. As soon as I installed and drove it with the Procal tune I could immediately tell the difference, better throttle response and extended shift points. Running 91 octane here in So.Cal.
I feel it was money well spent, $660 for the Procal and $80 install by ASE mechanic (had it all ready for him). Submitted warranty info was immediately acknowledged by Ford Performance.
Would totally do it again.
JDTremor
JD
Ranger Raptor, F350 SD Diesel Tremor, KTM500
Good experience here - drive-ability, power and mileage all improved over stock. Bought the unit for $650ish and found a local Ford Dealer to install it, using my FordPass points (they would have charged $130). I loaded the tuner at home using the recommended procedure and then had the dealer do the actual upload from the tuner to the truck.
Side note. I tried to find an ASE mechanic to install it..... none would do it, as I was providing the "parts". Finally found a dealer who knew what they were doing.
What kind of mileage gains did you see? I wouldn't expect huge gains, and I personally would be fine is there as no mileage difference, but I'm curious.
JDTremor
JD
Unscientifically derived 2-3 mpg - but some of that may have been the truck breaking in. I was getting 15-16 highway, now high 18s/low 19s. (75mph usually on FL turnpike). Around town generally around 17.
Your mileage may vary. LOL
Gotcha. I'll estimate maybe half of that is truck breaking in, another half might be the cal. Right now, my long-term average (since owning the truck, ALL driving collectively) is 17.0 MPG stock.
On singular trips mostly highway I got around 17.5 up to 18, but have not yet exceeded the EPA highway rating unlike my Mazda's which regularly exceed their EPA ratings on similar routes.
Although it is still cold weather here, so maybe once we get into spring it might change with factory cal. At least knowing the average over 5k, if I do Pro Cal it, I have a good comparison point.
What's really curious to me is why do some people report better mileage while others report no change or even worse mileage...are they just getting into the power more? Fuel economy is fickle, you get it or you don't.
JDTremor
JD
These definitely aren't Prius' LOL but love it! About the same mileage as the Jeep I traded it in for. 2020 JLU Rubicon on 35s.
TurboRanger
Jack
Oakley , Kalifornia
2024 Ranger Lariat 2.7
Mechanic
Can you use Regular gas if you had too With the tune ? My guess the knock sensors will see it
and limit boost
yelnoc2
Richard
Geneseo, IL
Had one for
4 years on my '19 Lariat and now about months on my Raptor. All good. Installed both myself except final actual "install" step, first one the dealer finished for $6 (cost of putting in the K/N which came with then) and current one by a Master ASE for $50. Wouldn't go back. Would that the tool wasn't locked to the vehicle, but price you pay for fun.
RANGER/HOBB
THE WORLD
Retired USAF
Everything is relative regarding mpg’s; Altitude, ambient conditions, air density, driving style, traffic conditions etc, all these affect fuel mileage.
Generally speaking, you'll see normal fuel mileage if you adjust your driving style, ie; accelerator application. Some will see additional mpg due to the factors listed above. 🇺🇸
RANGER/HOBB
THE WORLD
Retired USAF
and limit boost
No, due to possible engine knock.
The FP tune specifically calls for 91 + octane and I believe 93 optimal. You might be able to get away with 89 octane in a pinch, if this was all that was available but only for a short duration and altitudes below 3500 vertical feet.
No matter, using 89 will directly pull timing and affect overall engine performance.🇺🇸
TurboRanger
Jack
Oakley , Kalifornia
Mechanic
Ok another question If I am done with with using this tool Can i remove it and go back to stock
without the dealer. I have a SCT tuner for my 150 I can just select return to stock can you do this
with FP Procal
boraxman
with FP Procal
You can, not sure about warranty implications (if you do it yourself) though.
Daweism
Austin, TX
2025 Ranger Raptor - Velocity Blue (Ordered)
WHERE IS THE POLL?
Daweism
Austin, TX
I think it mostly has to do with the amount of lights, stop signs and traffic you run into. If you drive 60mph unimpeded for 10 miles you'd probably get 20mpg.
