Keep Drop-in Bedliner or Switch to Spray-in Bedliner
  • Thread starter Deleted member 8207
  • Start date
  • Watchers 4
T-Rev
I ended up with a drop in bed liner too. I don't plan on changing it. I have a tonneau cover and my truck is normally garaged. The amount of moisture it will see is not concerning enough to make me think rust will be a concern, i.e. liner rubbing through paint and moisture being trapped. More concerned about the rust on the frame the truck was delivered with.
SoutheastRangerRaptor
All, Appreciate all the feedback here. I guess the question I have is more about opportunity cost. Right now, I have the drop-in liner from Ford. This was a dealer order. However, is it worth scrapping the drop-in for a spray-in from Line-X? Its sounds like a resounding "Yes"! But, want to make sure I'm being clear.
If I understand you correctly, you aren't necessarily asking if spray-in liner is better than a drop-in liner (it is, and can personally speak towards Line-X quality), rather, asking if it is worth the extra expense + waste of replacing plastic drop-in liner for a spray-in....
Personally, for me, I would probably wait until time was opportune for me and swap out that drop-in for a spray-in just because I have had such good experience with the spray-ins that I have had over the years and I know they won't collect moisture like a drop-in plastic liner would. Waiting a little while won't hurt anything, and in fact, may be better because that plastic liner will scratch up the paint in some areas which they do anyway when they prep the bed for the spray.
In the end, I would do it if you plan to keep your truck for a long time, and if you haul stuff a lot, such as dirt bikes, project materials, etc... Otherwise, if you trade your trucks fairly frequently, just keep your plastic liner. The primary negative of drop-in liners is that they do have a known history of collecting moisture between the bed and the liner, eventually leading towards rust...
Critical Habitat
Twin Cities, MN
I had a drop-in on a 1999 F-150. The hard grooves on the bed were hard on my knees, so I added a 3/4" heavy-duty rubber matt on top, which also helped with impacts from hauling wood. Never noticed any trapped moisture or rust issues and because of the plastic grooves on the liner, it drained well.
docshelby
Macan Turbo
Optometrist
It depends on how long you’re going to keep the truck. I have the drop in liner and it’s fine and a 4 x 8 sheet of drywall does fit in between. you can always do a spray in down the road if you want to. I used my Ford points and the Ford drop in was like 200 bucks. Sorry, couldn’t justify the spray in for a truck I’m not keeping forever.
BriSco
'24 Ranger XLT, 2.7L V6
Always spray-in liner from Ford. Had them in my last 3 trucks, quality, durability and detailed finish is better since it is done at the assembly line when built. :thumbsup:
Except they aren’t done on the assembly line. They are sent out for bed lining on a batch basis after the trucks are built.
Deleted member 8207
Update: I decided to go with Line-X. I removed the drop-in which was a complete pain. I had to remove all tie-downs. The bolts were a %^$^& to remove and ended up stripping one with a T40. So, I'll need to order 1 bolt and 8 missing screws for the tailgate liner. I took it over to my nearest Line-X installer. Aside from some small overspray and a misalignment of the tailgate, the bed turned out great! I wiped off the overspray with some isopropyl alcohol and re-adjusted the tailgate myself.
Hootbro
Delaware
2024 Ranger STX 4X4
Yeah, they are loctite in. I had to use T40 impact bit and impact gun to get mine out when I installed my swing case.
twaderobyn
Tony
Joplin, Mo
2024 Ranger Lariat
Admin
My previous Ranger Lariat had a spray in liner that was tough as nails, and my new Ranger STX gets a spray liner this week, super excited. $550 bucks, bulletproof. I’m just afraid with a plastic liner that it will chafe and rub underneath and I won’t be able to stop thinking about that. I use my truck, but I also want it to last, and have that much more trade-in value when the time comes.
beaudointl
Tim
Ontario, Canada
Technician
I'd appreciate your thoughts here. My RR came with the Drop-in Berliner. The dealer ordered it. Otherwise, I would have opted for the spray-in. Regardless, I'm wondering if I should scrap the drop-in and get a Line-X spray-in. Is it worth it to do this? Should I consider another option e.g. BedRug, DualLiner, etc.? Please note that I also have a tonneau cover. I'm really on the fence here.
You already have a bed liner and a line-X can be sprayed in after. I like the line-X but in this case, to be economical, you could keep that liner until it doesn't serve its purpose, cracks or whatever then go for the spray in. Just a thought.
