Michel Jeanneau
Michel
Dover, NH
2019 Ford Ranger STX FX4 the black beast; 1988 BMW 528e with euro M kit
question for those who have turned on Trail control and other drive modes (mud/ruts), did you also turn on off-road page on APIM? Without the center console button, how do you get to the off-road page? I ask because my truck did not come with an e-locker (just an STX), and am guessing that turning on mud/ruts or sand will throw an "error-no locker";Thanks
Aircraft examiner
Stx could have the locker, my son and i do on our stxs.
I turned on all the stuff and i have off road gages on the cluster. No maps though
Sequoia
Dan
Germany
Ranger Wildtrak 2023
Thata what i have
How??
Other question: Does anyone know how I can set it so that the outlets in the bed have power even without the ignition on?
In the BdyCM, I can set the shutdown duration. I set it to 10 minutes for now.
Then there’s also something in the APIM called “Pro Power Outlet”… but I’m not exactly sure what that is.
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 6eae8021-57fa-4755-8640-d316c48702c3
Aircraft examiner
I just followed the spreadhseet on how to turn thise numbers on
Michel Jeanneau
Michel
Dover, NH
Yes, I know... my gen 5 STX had the FX4 package with a locker; this one was the only STX on the lot and did not have the locker; but I think I'll live. I did notice that Ford performance does offer a Ford Trac-lok for the M-220 as an upgrade (I know...not the same)
Ragner
Victoria
2022 ranger XLT
Supervisor
Which part exactly? What is the name of the 3 gauges?
These are the off-road guages.
The trans temp and and boost pressure will work but the oil pressure will only work with petrol variants. I've tried every combination for my diesel but cannot get the oil pressure gauge to work.
Michel Jeanneau
Michel
Dover, NH
I managed to turn on outside temp on IPC, and enable mud/ruts/sand mode; selected offroad screen type I on APIM but haven't seen it displayed on center screen yet. Also turned off seatbelt minder nag!
delisyd
Argentina
Ford Ranger Raptor 2024
Hey, I own a Ranger Raptor 2024
Were you able to enable TSR on this one? I managed to get it working, but the option in the SYNC menu is still greyed out — I can't enable or disable it from the menu.
DaStockST
Jeremy
Attempted to turn off the Belt chimes today in IPC but it didn’t work unfortunately
mAtTyG04
Matthew Glazier
Edmonton
2025 Raptor Ranger
Just picked up my 2025 RR 4 days ago. I've used Forscan many times. I tried the latest version and the 3 prior to that including v2.3.66 Beta . I cannot write in the IPC (as-built and non as-built) no matter what I try. All other modules seems to work fine but I really want to get the seatbelt chimes off. I'm wondering if it's because it's a 2025 with an 02/2025 build date? I'm not loading a profile. I've deleted all profiles. Tried everything I can think of.
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1745034633263-4k
Using the "good" cable:
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1745034688686-zq
DaStockST
Jeremy
Exactly the same that I’m experiencing. I can write in all modules but the IPC.
Aircraft examiner
I think i have come up with a way to remove auto stop / start
Go into the abs module and disable normal drive mode. Since alot of people get in and put it in sport mode immediately, wouldn't that knock out two birds with one stone? You would start in sport and auto stop / start is off
Michel Jeanneau
Michel
Dover, NH
I have made myself a mini-check list: engine on, ASS off, parking brake off, seat belt on, nag message off....yes the seat belt window pops up still (empty) and patiently waits for me to click OK...how do I get rid of that?
Aircraft examiner
Its in the as built section. Let me look at the spread sheet real quick
