Truck colour on 12" display changeable?
bubba Dave
kansas
2024 ranger
old
And my 2024 RED Lariat shows Blue. And I have read other posts that are Red. ??????
bubba Dave
kansas
2024 ranger
old
From Perplexity;
The "MyColor" feature in the Ford Ranger, as referenced in the IPC (Instrument Panel Cluster) module at address 720-06-02 in FORScan, is related to Ford's ambient interior lighting customization system. When enabled, MyColor allows users to select from a wide range of interior lighting colors for various parts of the vehicle's cabin, such as the gauge cluster, footwells, cupholders, door pockets, and more, depending on the model and equipment3.
Enabling MyColor in the IPC through FORScan typically unlocks the ability to personalize these lighting colors, either through the SYNC infotainment system or physical buttons (depending on the vehicle's generation and configuration)3. The eight settings for "enabled" likely correspond to different levels or modes of MyColor activation, possibly controlling which areas are illuminated or how many color options are available, though the exact mapping of each setting is not detailed in the search results.
It's important to note that while enabling this feature in the software may add the option in your menus, the physical hardware (LEDs and wiring) for ambient lighting must be present in your vehicle for the feature to work. Some users have reported gaining an "Ambient Light" button in their display settings after enabling related options in FORScan, allowing them to adjust color and intensity2.
In summary, enabling "MyColor" at 720-06-02 in the IPC module via FORScan activates or expands the ambient lighting customization options in your Ford Ranger, provided your vehicle is equipped with the necessary hardware32.
Thank you for setting me right. Another issue.... walk away lock 7Do-09-05. My 2024 Lariat was set to xxxx-0022-xxxx. I changed it to C022. I now show walk away lock but when I enable it after a few seconds it goes back to disable??????
Jalbano2
J
NYC
Maverick Lariat Lux
I think he is talking about when you turn on and off the truck, the ranger on the gage cluster. Mine is grey and matches my truck but i always wondered if your truck was another color, did that match?
My Raptor is blue and the animation is blue too.
