Deleted member 8327
It looks good, I'm thinking of 35's as well. All stock and no lift? with that wheel spec. is it a positive that provided that poke? I also want that poke but don't know what offset will give me that poke.TIA
Yes this is all stock with 18x9 wheels +1mm offset on 35”x12.5R18. I recommend going with 17” wheels since they are more abundant tire wise and much cheaper as well. I need to take these off until I get my 295/70R18 tires and praying that those will fit.
Hofstetm
Mitch
what are you running? It looks like I have to buy some 295/70/R18 to actually make this work with no rubbing.
I’m running Method MR305 NV's, 17X8.5, +25 offset, with 35x12.5R17 Toyo Open Country A/T III’s. Plus, a full sized 35 inch spare in the stock location.
Deleted member 8327
Guessing the 17” helps with the offset as well good to know.
Hofstetm
Mitch
17x8.5 with a +25 offset:
Ford Ranger Stock Raptor Ranger on 35s looks too good! IMG_5533
Ford Ranger Stock Raptor Ranger on 35s looks too good! IMG_5617
Mauibuilt
Al
Hawaii
2024 Ford Ranger Raptor, 2003 Toyota tacoma
Did you do a perch lift or is it all stock? Looks good with 35's. Looks like the tires stick out about an inch? Maybe the positive will work then. I had a negative 10 on my Tacoma and it poke. Which I'm trying to achieve.
Hofstetm
Mitch
No lift, stock suspension all the way around. Yes about an inch sticking out which is perfect, IMO.
Deleted member 8327
That STANCE, those WHEELS! 🤩 Do you plan to lift it to eliminate the rub?
May do 2.5” perch collar idk if it’ll help though. I ordered 295/70/R18 tires so I’m hoping they fit perfectly since these are just a hair too big.
RealTruck
Amber
Ocala, FL
Ranger
The perch collar may help since you've already made some room around the tires. Keep us posted!
Deleted member 8327
Perch collars ordered, 295/70R18 Tires ordered and a Turbosmart BOV ordered
Rufus
NYC
Do you have to recalibrate the computer?
