Stake Pocket Plugs
Aberk25
Alec
Ohio
2024 Ford Ranger XLT
After putting a hard tonneau on my ranger, I noticed as others have that water gets through the stake holes on the bed rails. I've seen others use silicone caulking to seal the covers on the rails. I didn't want to go that route and discovered these solid rubber grommets on amazon for 10 bucks. I used them to plug the holes under the rail covers in a way that is easily removable. I will have to wait till the next rain or wash to test them but in theory it seems like a solid plan. Gysxrda Rubber Grommet Kit 200... https://www.amazon.com/dp/B09XVDTQ8F?ref=ppx_pop_mob_ap_share
Ford Ranger Stake Pocket Plugs 1000013140
Ford Ranger Stake Pocket Plugs 1000013141
LeeHo
Lee
Niles, Mi.
Looks good - but how do you snap the plate back on with the anchor holes plugged?
Used that kit too. Also, you have a ton of other holes along both rails to plug plus, the 6MM & 8MM screw holes, plus you'll neeed to shove a tennis ball into the front two corners, plus the 1/4" gap around the tailgate needs to be sealed. Already several threads on this. Best bet is to just try to get it dryer. It most likely will never totally dry.
Jeffola
Southeast Florida
Business Development
Oh my buckeye friend, I was where you are now once too.
Prepare for disappointment, unless of course you like Swiss cheese. Ford has done a great job of allowing a myriad of accessories to work with the ranger. That comes at the cost of being waterproof.
I removed the top rails, broke the same clip on both sides! Laid down some vinyl and siliconed the places where the caps pierced the vinyl. 34 penetrations per side.
Ford Ranger Stake Pocket Plugs IMG_2965
Ford Ranger Stake Pocket Plugs IMG_2966
Jeffola
Southeast Florida
They have tabs on the short ends to pop into he plastic top.
slo_addy
Addison
California
2024 Ranger XLT FX4 2.7, 2004 Ranger Edge 3.0
This is smart. I'm gonna order those grommets and give it a go.
WESTRESCUE77
J
Westchester, NY
FWIW, I installed rubber grommets in my stake pocket holes and didn't see a material change in terms of water ingress.
I'm wondering if sealing the underside of the stake pocket covers with butyl tape would work. Obviously, you'd have to remove the bed rail caps, but it might be a better solution compared to silicone. Would probably look better too...
spike37
john
sutton ma
ford ranger lariat
Re those 6 inserts on the rails. I was told they aren't the actual stake holes. The stake holes are on the 4 corners. under the 6 covers thewe are holes for accessories. Is this correct? I put plugs from Amazon but water goes into bed. I guess the best way seal is covering with tape as someone earlier reported. But I think, with bed rug I have installed, won't worry about water getting in.
Aberk25
Aberk25
Alec
Ohio
Some tape probably would work. I haven't noticed enough water getting in my ford trifold hard cover even in a car wash to worry about doing anything else but if you're going for water tight that would be a good thing to try
D. Sampson
Dana
Albuquerque, New Mexico
2024 Ranger Raptor - Shelter Green Metallic
I think neatly sealing the stake pocket covers and also between the truck bed/outsides of the trim with neutral curing silicone is the way to go. I masked everything up with blue painters tape, and just took my time. I did the front corners of the bed with water sealing tape from the inside of the bed. Also did a tailgate seal kit. It's working really well so far with my retractable tonneau to prevent dust and water in the bed. My tonneau also covers the stake bed pockets.
dard6555
Does anyone have a good solution for the hole at the front corner of the bed?
Ford Ranger Stake Pocket Plugs 20250306_183723
Ford Ranger Stake Pocket Plugs 20250306_183755
dard6555
Did you ever find any answers or resolution to this issue? Thanks
I have not. I was going to remove my cover and seal the bed rail first and see how much intrusion I get from that hole.
Franco
Frank
San Clemente, CA
2024 Ford Raptor Ranger
I just put on a bed cover and finally recognized the size of the opening. Maybe a stupid question but does a lot/can a lot of water come in from that opening?
Pool noodles. Cut off a 12" piece. Slice that into two C shaped pieces. Fold those in half, and shove them into the holes. Trim excess.
