Rear axles - same as regular Ranger?
cleffe
Cgrus
24 Ford Ranger Raptor
Are the rear axles the same as the regular Ranger? Asking because I had one snap @ 1,500 miles
Raptor1996
Anton
Ohio
Are you talking about the axle shafts themselves? I would guess no, the rear end on the regular Rangers are dana units and the Raptors are AAMs.
dmac72
California
Just a simple 2H launch..
Wow. That's disappointing to hear. A friend of mine shredded his at the dunes on his F150 Raptor, but that was at the bottom of a bowl, coming in hot and cranking the wheel under full throttle.
Fingers crossed it was a one-off product issue and won't become a common occurrence among owners.
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
lol, what exactly is a simple 2h launch? Gently pulling away from a stoplight? That's not usually called a "launch". Brake boosting with the accelerator floored? Not usually referred to as, "Just a simple..." anything.
I wonder if the rear diff was locked too? No slippage could definitely cause damage with the full amount of torque going to the rear wheels
cleffe
Cgrus
It wasn’t locked
Crapblaster
2025 F150 Spave White Platinum, 2024 HPR Ranger Raptor
It should be able to easily take it even with the diff locked. Hopefully it was just a defect. I have heard of some Bronco owners breaking them with trail turn assist.
Stevedbvik1
Michigan, USA
2022 Ford Ranger Tremor
It appears to be a fatigue failure. Meaning the initial stress happened several launches ago and it eventually let go on your 2H launch. If the 2H launch caused it then it would be a clean break.
Satex
Blake
San Antonio
2024 Ranger 2.7 Ecoboost
The truck should be able to handle both scenarios
That still doesn't define what you mean. In your situation, what do you mean by "a simple 2H launch?"
DirtDerrick
Nathan
Atlanta
dirtderrick.com
People Person
Did mine around same mileage. Couldn’t find a stronger aftermarket option. Had to go back factory and at the time I had to get the whole rear housing gears everything, cost around $7k. You’re Blessed because now you can buy the individual parts (left/right link below). Had the links handy because another guy who snapped his asked me yesterday about
Left Axle
Right Axle
A sales rep at Detroit Axle told me in January that they were working on them & should be out by March. I’ve not followed up or know of an aftermarket option.
“And speaking of the axle, to an old-school four-wheeler this rear axle might bear a strong resemblance to a Ford 9-inch. After all, the backside of the pumpkin is smooth and there’s a dropout centersection up front. Well, it’s not a 9-inch. Instead, it’s a bit smaller. The axle comes from American Axle Manufacturing in Thailand (where Ford also sells this truck). It has an 8.9-inch ring gear, electronic locking differential, and 4.27:1 gears.”
