Exodus 4x4
- First Name
- Bubba
- Joined
- Jul 8, 2024
- Threads
- 3
- Messages
- 12
- Reaction score
- 48
- Location
- New Braunfels
- Vehicle(s)
- 2024 Ranger Raptor
- Thread starter
- #1
This is hands down been my favorite build to date!
I agree, the RR is all about the super sophisticated high speed desert runner suspension. If you're going to go through and replace everything why not start with an FX4? Its my theory if you need that much clearance you probably need a Wrangler or a Bronco.Tbh, I don't like that build
1- Build costs is very high due to portals.
2- Ground clearance is great but takes a lot from what this truck is capable off, in terms of turning and maneuvering.
3- It will defiantly have body roll with that height.
4- I don't think these fenders will stand abuse even with that clearance, even with a good offset wheels they will rub, while bottoming out.
I would prefer a Prerunner build with bigger shock ,bypasses and bumps on all corners with 35's.
The extra cost of the portals will go into better refining the Prerunner build instead of putting it in the portals, its all about the details they say.
Good build though, no hating but it's not my type of build at all.
Did you even watch the video to understand that we did NOT replace everything, particularly the suspension? If you ever run one of these hard enough youāll know exactly why you need that much clearance. Iāve spent a lot of time putting platforms like this and Bronco in the air and Iāve smashed the lower pivot mounts into ground a lot. Even with the added 3.88ā of clearance below, itās still close. Not to mention the added stability of the wider stance. The truck is so much better with the portals than without.I agree, the RR is all about the super sophisticated high speed desert runner suspension. If you're going to go through and replace everything why not start with an FX4? Its my theory if you need that much clearance you probably need a Wrangler or a Bronco.
I like options, I don't have a problem with this kit being put on the market. Its not for me. I'm not into anything that extreme. I'm just planning on a two inch suspension lift and 33" tires, just plan on overlanding.Did you even watch the video to understand that we did NOT replace everything, particularly the suspension? If you ever run one of these hard enough youāll know exactly why you need that much clearance. Iāve spent a lot of time putting platforms like this and Bronco in the air and Iāve smashed the lower pivot mounts into ground a lot. Even with the added 3.88ā of clearance below, itās still close. Not to mention the added stability of the wider stance. The truck is so much better with the portals than without.
