StillwaterRaptor
- Thread starter
- #1
Just finished up the second attempt at getting a light setup on my FMI light bar mount. I'll outline the process and you can see the final results.
First -
Installed the light mount.
Installed my KC Hilites Gravity 6 lights (6 total)
They weighed 25 lbs and the lights jiggled as you went down the road.
Uninstalled them and the light mount.
Second -
Unwilling to give up - I reinstalled the light mount
But this time I used their included support brackets. Yes it drills into the bumper - No I didn't really care. (ARB are you listening I want that summit bumper)
Huge improvement in stability.
Second part 2 -
I think took my old fog light kit and repurposed it.
It is 2 Flex Era 3s, and 4 Flex Era 1s. It's this kit
I do have the materials to make Deutsch connectors - so I made a loom for these.
Each light has 3 wires.
The Flex Era 3 - one mode is SAE compliant and one is full bright
The Flex Era 1 - One mode is amber backlight, one mode is full bright.
So one mode is SEA + Backlight (pretty legal)
The other mode is FULL BLAST (super not legal.
Here is a video:
It goes in this order:
Low Breams, no fogs
High Beams, no fogs
Low Beams, KC Hilites SAE Fogs
Low Beams, KC HiLites SAW Fogs + OEM Fogs
Full Blast
Now To Wiring
Aux 1 - KC Hilites RGB Roc Lights - They pull 2.5a on the 5a switch
Aux 2 - Signature Lux Grill Lights & SAE Mode for Flex Era 3 and Backlights on Flex Era 1 - That Pulls 7.3a on a 15a switch
Aux 3 - Empty because it's in the rear
Aux 4 - Empty because it's in the rear
Aux 5 - Midland GMRS Radio
Aux 6 - Full Blast KC Hilites Flex Era 3 and 1s - This pulls 17a on a 25a switch
First -
Second -
Second part 2 -
Here is a video:
Low Breams, no fogs
High Beams, no fogs
Full Blast
Now To Wiring
