ProCal Tune for Ranger Raptors in California?
Blue_Raptor
Simi Valley, CA
I’ll add my data point for costs on SoCal dealers install. I was at my dealer today, Price Ford in Simi, and they want $300 for the job, charging it for 1 hour labor. So I guess when I get the tuner I’ll be going somewhere else for install. Sigh.
pasali
Paul
Livermore CA
Carpenter
@Caonguyenxxx, please explain what pre-staged means. I have my tune (Ranger Raptor) and I found an ASE mechanic willing to do it. What else do I need to do besides drop off the vehicle with tune in its original box? TIA
Caonguyenxxx
Nguyen
Sacramento, CA
You have to log on to the website, register your VIN, then download the Tune Software Version to your Procal device.
bluemarlin25
James
texas
I’m still on the fence as to whether I get this done when they come out with the 2025 version
my dealer said 2 hrs labor to install and verify/test it….so $400
plus the tuner
plus the added fuel cost for having to run premium gas
Blue_Raptor
Simi Valley, CA
plus the tuner
Aren't you going to be running premium anyway? The stock tune allows for boost and timing adjustments to match fuel octane. If run less than premium it will drop boost and retard timing and you will not be seeing full power output. Also, in very warm weather you will be much more likely to get detonation.
bluemarlin25
James
texas
Silly me…. I didn’t realize it wants premium
I’ve only had the truck for 10 days and I’m still on the original tank of fuel the dealer provided
guess that removes one of my decision points…and probably the most important one
I’m going to get the tune when it finally gets released
thanks for the heads up on the fuel…I never was told that when I bought it
Blue_Raptor
Simi Valley, CA
Sure thing!!
Also, the quote you got for $400 from your dealer for install is crazy. Over in the thread looking for installers in SoCal all of us have reported wild discrepancies between different installers. Note that Ford Performance only requires it to be installed by someone with an ASE certification and you then provide the info to them and register in order for it to be covered under warranty. So if you call around you are very likely to find a shop that will install for you for much less. Of course, if you don't care about warranty you can easily install it yourself.
