Had the pickup running, not running - no difference.You have to have the pickup RUNNING.
the green light is above the outlet and comes on when the pickup is running
Based on the Rangers manual, then I would assume the 20A Fuse #34 forHad the pickup running, not running - no difference.
I plugged in my wife’s small Mercedes air compressor to fix a bicycle tire flatOut of curiosity, what did you initially plug in and attempt to use? Could that have blown the fuses pulling too much amps?
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.I went to use the power outlets in the bed of the truck and it didn’t work. Checked the one in the center console and that is dead as well. Manual doesn’t mention anything about turning on a switch. Not sure why this doesn’t work. Any ideas?
Same problem here, the 12 volt outlets work, both 110 volt plugs do not work and neither one of the "have power" lights are lit. brought the truck into the dealership and after leaving it there for 2 days they returned the truck to e stating they have to order a circuit, neither I or the service advisor knows what means but he said the circuit is on backorder and he will call me when they get the partI went to use the power outlets in the bed of the truck and it didn’t work. Checked the one in the center console and that is dead as well. Manual doesn’t mention anything about turning on a switch. Not sure why this doesn’t work. Any ideas?
Having the same issue where the USB power points work fine but the outlets don't work. Checked the fuses and they look fine. Guess I gotta find time to get it to the dealer.Same problem here, the 12 volt outlets work, both 110 volt plugs do not work and neither one of the "have power" lights are lit. brought the truck into the dealership and after leaving it there for 2 days they returned the truck to e stating they have to order a circuit, neither I or the service advisor knows what means but he said the circuit is on backorder and he will call me when they get the part
