Flowkottu on Amazon Retractable Hard Tonneau Cover
RangerDangerStranger
SF Bay Area
2024 XLT 4x4 in GreyBlue.
Cool Dude
Thanks, I'll try reaching out to them too to see if they can send me some longer ones.
The ones I got from DSampson, that he said he got from Flou have the clamp bolt lower, so the top face of the bracket can flush with the underside of the cover, which stops the warping problem that required the spacers in the first place., they also have modified longer side brace bolts. I found i didn't need them though, so didn't install them. The took a bit if finagling, but i got the cover to roll in and out smoothly, very little drag. 👍
ihor1337
I reached out to them, they replied the next day and said they will send me "updated bracket" and attached a picture. It looks like it's just a set of spacers and longers screws for the existing brackets, which should solve the warping and binding problem (hopefully).
I was thinking to eventually (a year from now probably) put a t-slot bed rack and a tent on it, but now I'm not so sure if I would trust this cover to hold 200lbs of dynamic weight... Will probably need to re-think my setup when the time comes.
SF Bay Area
Cool Dude
They have a better bracket- see the pick. I still eneded up having to use a small spacer to keep things flat. I could eliminate the the small block, but i'd have to trim the foam on the cover, not needed right now. If i were you, I'd push for a free set of the extended brackets, also with the spacers, and then I'd buy a second set for a total of 8, 4 per side. that should handle the load? Hope you have your Bed J-brackets done if your truck needs them.
theweinerback
Steven
Orlando, FL
I'm eyeballing this cover--thanks. Do you think I would need to get ahead of it and ask for the "better" brackets on order? I am a little concerned about the idea that a 2-person T-slot tent might be sketch with this cover.. fortunately I have a '25 built in Feb of this year so I don't believe I need to be concerned about the J-brackets.
Thanks!
ihor1337
Hm, if I’m interpreting the instructions correctly (they're rather poorly translated), that small metal block in your picture is meant to go between the bed rail and the plastic cover—right where the bracket clamps onto the bed. It helps fill the gap between the metal bed rail and the plastic piece to ensure the brackets clamp securely and don’t slide.
SF Bay Area
Cool Dude
yes, i'm miss using them, but the instructions were trash, i felt a hands on approach would work better. I would't accept the spacers as a fix, get the deeper correct brackets if you're able. My install is very stable, but four more brackets might be in order if I was gonna buy anything on top of the cover.
D. Sampson
Dana
Albuquerque, New Mexico
2024 Ranger Raptor - Shelter Green Metallic
D Sampson above complained to Flowkottu and got the right brackets, he had an extra set when I bought off of him. I just put them on last week and they fit perfect..
Correct, except my cover is slightly different, the brand is Willmoso.
I contacted the company I bought it from (Sadeloos - bought through Temu - ugh!!) to purchase additional brackets. I'll tell you, it was a weird transaction, but I was able to get them and they were inexpensive. I did this because I wasn't sure if two brackets per side would be strong enough. After I installed it, it was really pretty sturdy with just the two brackets per side, so I sold the extra brackets.
I want to note that before I installed it, I made and installed spacers under the stake bed caps (to make it more sturdy as well). I then sealed the stake bed caps with neutral curing silicone. I also sealed along the bed between the plastic trim piece and top of the truck bed. I'm using a tailgate seal kit as well, and everything in the bed is staying dry, no leaks.
Another note: The bigger flat top piece/cover of the roll up canister (part M2 from the instructions) was slightly bent when I received it, damaged in shipping I guess. I didn't think it was a big deal at the time, so I didn't do anything about it right away. Well, it started to bug me, so I contacted Sadeloos on Temu to see if I could purchase a replacement part from them. They ended up shipping me an entire new tonneau cover at no charge. I have a completely unopened new tonneau cover sitting in my garage now. So I have every spare part, including 4 additional clamps. Trying to decide if I'll sell parts of it, or just sell the whole tonneau for cheap after I replace my bent part.
Canoman
DFW, TX
2025 Ranger Raptor, Carbonized Gray
Chemical Engineer
Are the locks the same on the Willmoso and the Flowkottu? The Willmoso on Ebay shows it's a combination lock. Flowkottu doesn't show lock detail on Amazon.
Edit: Videos on Youtube show a key on the Flowkottu.
Canoman
DFW, TX
Chemical Engineer
Pulled the trigger last night on the Flowkottu. Should be delivered before the weekend.
Canoman
DFW, TX
Chemical Engineer
Flowkottu arrived. Step 2 in installation is to drill a 20mm hole in the front of the bed. Yikes! Didn't have that in mind. It's for drainage from the canister. Tough to want to drill into a brand new truck. Just gotta get over it, I guess.
ihor1337
If it makes you feel any better those plugs that they tell you to drill are cheap (like 10-20 bucks on Amazon) and are fairly easy to replace. Just be careful not to drill through the cab as it’s pretty close.
