Anyone bummed out '24 Ranger is using the same gas tank (and hence size) in the new gen ..18G tank again
BigMeatsBronco
Allan
Oregon
self
I saw a rumor somewhere that the bronco tank fits the opposite side...
Yeah it's true the Bronco has the same rear suspension design as the ranger Raptor so they're a cut out and the rear of the tank area is identical or a mirror image of the opposite side Ranger Raptor fuel tank. The crossmember could be in a slightly different location other than that the four-door tank should fit perfectly and there's also a shorter tank which is in the two-door version of the Bronco which may be used as well. The biggest difficulty would be rerouting the exhaust and all of its components to clear the new fuel tank and it could be done easier with the shorter fuel tank out of the two-door.
jbethune
NC
2024 2.7 Ranger XLT
Honestly these aftermarket tanks are actually too big. Even in my full sized truck I never felt slighted by 26g. (Granted I’m not towing much with this…that does change things somewhat) What is really needed is something in the 24-26 gallon range that is no lower than factory when installed.
WashingAvoided
Ontario, Canada
Highlander, moving to 6g Ranger 2.7
Lot of people where this doesn't apply to or don't know, but when towing anything with some weight or a large front area the gas mileage tanks. To anyone long distance towing an 18G tank means you're constantly searching for the next gas station. I tow about 6 to 8 times a year long distance and I want an alternative to a full size truck. The 2.7 ticks all the boxes for me, except for the gas tank, which I'll have to live with cuz I'm not sure I can handle $2K to $4K for an extended tank.
johndeerefarmer
2017 F150 and 2020 F350 and 2022 Ford Escape
What fuel economy do you get towing?
We stop about every 2 to 2.5 hours anyway for people and pet breaks
mAtTyG04
Matthew Glazier
Edmonton
2025 Raptor Ranger
