- Joined
- Feb 27, 2025
- Threads
- 11
- Messages
- 253
- Reaction score
- 252
- Location
- United States
- Vehicle(s)
- 2024 Ranger Raptor
- Occupation
- Electrical Engineer
- Thread starter
- #1
First, the proof, I did own a 2016 Mustang GT PP and at about 17k miles I decided to have the dealer install the Ford Performance Stage 2 Power Pack under warranty. See attached images of the Ruby Red GT PP.
Stock, the 2nd generation 5.0L (which has the former Boss 302 forged rods, high flow heads, valve lift etc. from the S197) was rated for 435 HP / 400 lb-ft of torque, but peak torque was up high at 4,250 rpm.
The Stage 2 Power pack was rated for up to 456 hp / 424 lb-ft torque, but added 40 lb-ft in the midrange where it really needed some boost...so a Stage 2 Power Pack Gen 2 Coyote 5.0L makes the same peak power as the Pro Cal tuned 3.0L V6 for the 2024 Ranger Raptor I now own...BUT is far more torque rich and with nearly 100 lb-ft more torque than the 5.0L!
In fact, it makes the same power and more torque than the 6.2L 5th Gen LT1 in the Camaro SS / Corvette (455hp / 455 lb-ft) which in my opinion is an excellent engine in terms of torque / power for road course and also for truck applications where its de-tuned a bit to 420 hp (from 455 in the SS, C7 vetts).
2015-2017 MUSTANG GT COLD AIR INTAKE AND CALIBRATION POWER PACK 2| Part Details for M-9603-M8A | Ford Performance Parts
My perception of the two engines is that unless you are boosting the 5.0L or doing some E85 custom stuff with forged Mahle internals, the 3.0L V6 with a Pro Cal is the more enjoyable engine with more usable power EVEN though it doesn't sound as amazing as the 5.0L Coyote did with a Power Pack and Corsa exhaust.
I would personally take the 3.0L any day over the 5.0L Gen 2 for a truck application. Now the Gen 3 5.0's were a whole new animal, much broader torque band (even if not higher torque), but with the 10 speeds...it's not really buying you much (the Gen 3's broader torque band would have been nice with the 6 spd Getrag's or the 6R80's in the autos since the gear spacing was wide).
I've seen several posts about people longing for a V8 in the Rangers....aside from the sound, you're NOT missing much and, in a truck, I'd MUCH rather have that massive low end for most "truck stuff" uses than the peaky 5.0L.
This is about as apples to apples as you can get between the 5.0L and the 3.0L, both Ford Performance Tuned. I think the 3.0L NANO is better than people give it credit for and makes very similar power (with a Pro Cal) to Audi's 3.0L and 2.9L V6 Turbos which also have a very similar CGI block design from the same supplier.
These are great engines and when factoring in their slightly differing characteristics, don't forget that you cannot even FIT a 5.0L DOHC V8 into a mid-sized truck chassis, so it's not even an option (especially with the much more capable Fox Live valve shocks / longer arms). So, the 3.0L offers more usable performance in a more compact package.
Even stock, the 3.0L is still pretty good and I don't think it's given enough credit for what it really offers at its size / weight. Unlike the 3.5L, the 2.7L and 3.0L were designed from the start specifically for Turbocharging applications.
Personally, I think Ford should kill the 3.5L aluminum block and design a new large displacement TT V6 for the F-150's with the same tech in the NANO's or since the F-150 and larger chassis can accomodate a DOHC V8, consider a TT Inline 6 like Dodge's 3.0L Hurricane (except more reliable than that thing).
Hopefully this gives some consideration to those loathing the 3.0L V6 as if the 5.0 was really that much better. It's not aside from the sound.
