When will 2.7 V6 be available on Ford.com Build & Price?
chasvs
Tampa
2019 Ranger Lariat
I've been trying to order a 2024 Ranger since ordering became available. The only option for power Train is the 2.3 ltr 4. When will the 2.7 ltr V6 become an option to order?
Reactions: LCW
goalieThreeOne
Memphis
2022 F-150 Raptor
Later in the model year. No date has been announced
Deleted member 6764
"Late Fall", likely means December is my guess. May be in Job2 which earliest is speculated to be end of November to December, but likely will slide with Job1 and could push to next year easily.
fordtrks4ever
Tim
Perkiomenville, Pa
My dealer had said Job 2 would probably be late January unless it changes.
Like Job 1 start keeps moving.
2.7 is late fall and a Job 2 build.
I will be getting notified by dealer when 2.7 is available to order
Tony Sorrento
Tony
Western NY
2021 Ford Bronco
Auto Sales
I wouldn't even hold my breath on the 2.7 for 2024 .... just my opinion
davey690
Ontario
Ford Sport Track
Health and Safety
davey690
Ontario
Ford Sport Track
Health and Safety
I’m just wondering if it’s worth waiting for the V6?
Ranger#5?
GumbyDammit
nobody can make the decision for you. Do you have a specific requirement for the V6 that is a dealbreaker for you if you don't get it? Does it just sound good in theory having a bigger motor? The 2.3 base will be available earlier and cost less initially and over time (maintenance) and get better MPG. Do your own cost/benefit analysis on paper and the answer should be clear.
davey690
Ontario
Ford Sport Track
Health and Safety
I just feel the V6 would last longer.
Also I’m thinking in a truck a V6 makes more sense.
I’m open to suggestions.
goalieThreeOne
Memphis
2022 F-150 Raptor
fordtrks4ever
Tim
Perkiomenville, Pa
Your opinion is noted.
If it is 2025 so be it.
It is not like I need a new Ranger in 2024 but I would like one.
If you need a new Truck ordering one will drive you nuts waiting.
jdlapointe
Maine
Project Manager
The 2.7 will be available for Job 2. However, Job 2 gets delayed with Job 1, so it will definitely be sometime next year.
I personally would only get the V6 if I was towing heavy (6,500lbs+) all of the time. The 2.3L has proven plenty capable, and reliable thus far.
Ranger#5?
GumbyDammit
^this^ My Maverick 2.0 has 250hp and plenty quick and capable. Compared to the 4 Rangers I've owned before, 2 4 cyl & 2 6 cyl - these modern turbos are like in a different universe! :sunglasses:
1986YellowRanger
Ohio
Edge
Hopefully we will be able to order in October or November... I’m holding off for the V6 simply because I will enjoy the extra power and I prefer to cause less stress on the engine and turbo. I tend to drive my vehicles forever, my theory is that a more powerful engine stressed less over time will delay the inevitable oil leaks and turbo failure.
Ranger#5?
GumbyDammit
I would cautiously say BEST case scenario is November or even December- and that is if there is no strike. BTW, is that V6 a Twin Turbo? If so, you have 2 more cylinders as well as 2 turbos to worry about failure and lifetime maintenance on. If I end up trading up my Maverick for a Ranger at a later date, I will look for a Ford approved and warrantied up-tune kit that I've heard gets you to ~300 hp + possibly a cat back system. That puts you near the performance of the 2.7. My 1st choice is probably a NIssan Frontier King Cab S that comes standard with a naturally aspirated direct inject 310 hp V-6 and no turbo issues to deal with at all. Lower MPG is the tradeoff :like:
