Turbo boost in psi?
Paf1yyc
Calgary
Ford Ranger Tremor
Does anyone know how to get the boost gauge to show up in PSI? Mine only shows bar and I can’t find anyway to change it. Thoughts? For context I have a Canadian spec Ranger Raptor. Thanks.
joordan
Italy
ranger wildtrak 2023
you need to change the unit in the settings
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
Are you able to clarify which setting? I've also been wondering this. I've changed my settings to psi in the vehicle settings menu, however only tyres are measuring in psi, boost is still in bar.
joordan
Italy
I'll give a try later...I thought changing in the settings would have make it across any gauge
Paf1yyc
Calgary
Ford Ranger Tremor
The only pressure unit setting I can find is for tires and it doesn’t impact the boost gauge units. I have seen other members of the forum indicate they can see psi but I cannot find the setting anywhere. Is it a US model thing that Canadian models don’t have?
joordan
Italy
Tried any settings but it does not change the turbo unit. You may do it in forscan
