If you have a 2" level and tow, you might notice the rear sagging with a heavy load. Here are a few ways to keep the truck level:
Add Airbags – Airbags help support the rear suspension and keep the truck level when towing or carrying a heavy load.
Upgrade Rear Springs – Heavy-duty or add-a-leaf springs can provide extra support.
Timbren or SumoSprings – These help reduce sag without needing air adjustments.
Weight Distribution Hitch – If towing a trailer, this helps spread the weight more evenly.
Each option has pros and cons, but airbags give the most control since you can adjust them as needed.
