Informational - Science / History Behind In Situ DLC Coatings for ICE and Transmission / Gearbox Applications
Address - https://www.nasa.gov/technology/tech-transfer-spinoffs/5-auto-innovations-driven-by-nasa/
Hyperlink: 5 Auto Innovations Driven by NASA - NASA
The purpose of this post is informational for anyone interested in learning about and then taking advantage of In Situ Hydrogenated DLC Coating technology, otherwise known as TriboTEX. I am not a chemical engineer but am a degree Electrical Engineer working the field of Plasma Technology and automotive systems are a hobby of mine.
I generally apply the same level of scrutiny and study to automotive technologies that I do in my professional capacity and am sharing what I have learned over the years studying Extreme Pressure Additive Packages (EP additives) like MoDTC organic moly and ZDDP in motor oils, base oil formulations like PAO, Ester, Group III+'s etc. as being someone who is passionately curious.
I generally try to avoid relying on here say such as "this person said this and did this etc.". Sometimes there is merit to it, sometimes there is not. This post is primarily focused on real data and real-world standardized testing (see links and attachments).
Background Information
1. I do not use "oil additives", unless you know the chemistry, you're upsetting the balance of the oil's additive package, and it could lead to unintended consequences. For example, people used to add MoS2 (moly) to motor oil as an EP additive to reduce wear rates and improve power by reducing friction losses in ICE's. What they didn't know at the time is that when MoS2 is exposed to moisture, it absorbs hydrogen, rapidly breaks down and becomes abrasive! So MoS2 (non-organic moly) works well in hermetically sealed applications like CV joint grease, but not in motor oil.
2. Manufacturers across all companies have been using vapor deposited DLC coatings for quite some time on factory engine parts to enhance service life. The problem with vapor disposition is that once the coating wears off the part, you would have to disassemble the engine and replace or resurface / recoat the part, making factory DLC coatings a one and done deal.
DLC Coatings
3. Once OEs started to use DLC coatings, they realized that current motor oil formulations at the time (early 2000's) did not provide adequate wear protection for them as ZDDP tended to not form a tribofilm on DLC coated wear surfaces like it does on bare steel (i.e., cam lobes, piston rings / cylinder walls, main bearings etc.). Parts that were DLC coated from the factory might be something like a valve stem to enhance the seal of brass bushings and limit oil loss for example, also reducing heat and wear rates, thus extending service life and reducing oil loss. So, Infineon developed MoDTC, an organic moly compound EP additive that is now common in modern motor oils and works synergistically with DLC coatings while also being a primary friction reducer, something ZDDP does not do (e..g., ZDDP can actually increase friction slightly, but the tribofilm forms rapidly over the bearing surface that operate in boundary layer lubrication regimes, aka metal on metal contact where there is not enough velocity to form a hydro film or fully form a hydro film).
DLC Coatings for Valve Train Components
Terms and Definitions
ZDDP - Zinc dialkyldithiophosphate, a common EP additive in motor oil that gives it the "golden color". This additive is the primary EP additive that reduces wear during boundary layer and mixed mode lubrication regimes where there is direct metal on metal contract. Boundry layer or mixed mode lubrication regimes occur when there is not enough velocity between rubbing pairs or when the load exceeds the capacity of the film at a given velocity. ZDDP forms very rapidly but also decays very rapidly. It is ecologically toxic to aquatic life and one reason why the EPA has been putting increasingly stringent limits on ZDDP concentrations in modern motor oils, consequently that works against wear. There is also an optimal concentration, too little or too much yields sub-optimal wear. ZDDP tribofilms also tend to increase friction slightly but significantly reduce wear rates.
MoS2 - Non-organic EP additive that was also developed in the 1940's. It was initially used in aircraft engine oils to permit short term dry running operation of the piston engines in case the oil pan was shot out during combat (allows for a few minutes of dry running of the engine giving the pilot a chance to land). It's a common EP additive in heavy duty greases but is highly susceptible to water absorption in which it turns abrasive. So, it is not ideal for motor oil applications despite its excellent EP properties but does work well in grease applications that are hermetically sealed like CV joints.
MoDTC - organic derivative of MoS2 designed to eliminate the water absorption issue and is now a common EP additive in modern motor oils. For example, Mazda uses it in their "Moly 0W-20 and 5W-30" motor oils. I believe Ford and others are using it now in their factory oils to enhance fuel economy and reduce wear rates of factory DLC coated parts. It was developed by Infineon in 2009.
What is TriboTEX and Why Do You Care?
TriboTEX, otherwise known as Synthetic Magnesium Silicate Hydroxide, is an In Situ DLC coating originally developed for industrial and military uses. It was heavily funded by NASA, Argone National Labs and several other entities including the DoD. Early target applications included wind turbine gearboxes, hydro power generator reduction gearboxes and heavy truck differentials / transmission for military vehicles all of which are subjected to extreme torque loads. Currently it is being explored for additional uses in helicopter gear boxes to extend service life.
In Situ is Latin and simply means it "in process". As mentioned above, DLC coatings are not new, however In Situ DLC coatings are and provide key advantages over traditional Vapor Deposition methods: 1. can be retrofitted into existing mechanical assemblies using the lubricating oil as a carrier to locations of heat and pressure, which causes the film to form over time 2. Can be replaced at regular intervales as the film wears down after initial formation without disassembly.
Advantages of DLC Coatings
1. Reduce friction of rubbing pairs (i.e., bearing surfaces that do not have a complete hydro film during normal operation), in many cases to levels of "super lubricity".
2. Reduces wear on the metal surfaces, as the film is what is being worn away, not the surface of the metal bearing face. The film lasts longer due to high hardness than bare surface even with common EP additives like ZDDP in oils.
3. Can enhance film strength by enhancing oil adhesion to the surface, thus furthering the load bearing capacity of the fluid film and even allowing the film to exist under higher load conditions than it would otherwise.
Now that we understand the advantages of DLC coatings, I hope you can begin to see why an In Situ DLC coating is advantageous and why I personally use and recommend them.
Please see the attachments for detailed information. I will add subsequent posts with more information as time permits.
Recommendation's for Application
1. Dosing (quantity of material) is one of the most important aspects to get optimized. DLC coatings are a film that requires a certain amount of surface area to be covered in order to provide full benefit, if you don't use enough, the film will not completely form to reach super lubricity in the areas of heat and pressure. Conversely, more is not always better either, there's a point of diminishing returns, so just like additives developed and tested in motor oil formulations, use it in the recommended proportions for a given application.
2. Apply after fresh oil change to allow for maximum wear in time on engines. Typically, it takes 40 motor hours to fully form, in some instances a bit longer if loading is light. For transmission / gearbox / diff applications, as long as your not near the end of the fluid service life, your fine.
3. For transmission applications, NEVER use on transmissions with wet clutches (i.e., dual clutch transmissions or sport bikes) as the tribofilm will cause the clutch to slip!
- You might ask why it doesn't cause torque lock clutch plates to slip in automatics? Simple, the torque converter is handling most of the power transfer during the lockup phase, so the torque lock friction plates don't see much heat load during lockup on normal driving. I would NOT recommend towing during the wear in phase when apply to automatic transmissions. Just drive normally like during engine break in, then you can drive it hard / tow after wear-in. I have yet to see a single report automatic slip from Tribotex application and have used it on my own vehicle's multiple times at suggested intervals.
- Larger transmissions with more gears may require two applications due to the much greater surface area where tribofilms need to form. It's simple, a 10-speed auto in the RR is going to have much more surface area than the automatic in something like a Mazda 3 or Honda Civic. The same applies to engines.
4. Do NOT use on a new engine that is not fully broken in. You will interfere with the break-in process. I personally do not use until 10k to ensure all wear surfaces are fully worn in and I've removed production contaminants via oil changes.
Consider also it has limitations. It is not going to fix a spun bearing. It is not going to fix a bent rod or cracked land. It's not going to add 50HP like the FP Procal, but it may give you back up to 3 - 6% of your RWP by reducing losses in the drive train and engine when comebined while also enhancing the robustness of your lubricating oils during extreme loading conditions.​
1. Reliability​
2. Wear​
3. Power and Efficiency​
Consider the whole package and you can decide whether you think this technology is beneficial for you or not. There are other options on the market like Arc Oil and Liqui Moly that's based on Hexagonal Boron Nitride, however they have considerable draw backs and do alter your oil's properties as they also contain chemical friction modifiers, stabilizers etc. where TriboTEX is only an DLC coating that uses your lubricating oil as a carrier to locations of heat and pressure where it forms a robust tribo film over about 40 motor hours (500 miles) of operation and works synergistically with ZDDP and MoDTC that's already in most OE motor oils formulations.​
It also has the most rigorous and well documented testing behind it compared to all other options on the market and that is why I use it personally. Now...if only I could fast forward my RR to 10k miles...I may do it sooner on this truck than in the past as the only big risk is preventing wear in of say a piston ring, which occurs within the first thousand miles anyway.​
Here's some great discussion on the subject from Rudenko on some of the development history, application and questions that arise:​
I also wanted to point out something for additional context. There are a lot of "one liner comments" by those who are ignorant about the technology and claim that it's fraud, snake oil etc. because they do not understand it.
Disparaging statements often include things like "it's a scam because it says it repairs metal and I've never seen an additive that puts worn metal back", which is a complete mischaracterization of their statement that it "repairs worn surfaces".
The context is pretty straight forward, the tribofilm forms over the worn surfaces, so it essentially reconditions the surface by forming a film over areas of high wear from heat and pressure generated by loading. The film can range from just a couple of microns up to about 40 microns depending on the depth of surface asperities. Again, consider the context of the statement.
Hopefully some of you find this beneficial and you can add your feedback on experiences that will help others looking to improve performance though verifiable testing and applications.
Aircraft examiner
Sounds interesting to try but i still have 7k miles to go, till 10k
Just to clarify, there is no hard rule of 10k, that's just a good safety factor I based on some information I had read on building turbo charged engines that suggested some rings can actually take up to 3k-6k to fully harden after initial wear in. Since 10k is my 3rd oil change (I usually do 1,500-mile initial change to get the silicone out, then 5k, then 10k), it makes a convenient point.
Plus, it gives you time to make sure there are no infant mortality issues with manufacturing as there's no point in spending the money and time to do it on car that say has a defective rod bearing or a bad phasor that shows up early in its life. Those things may be rare, but they do happen, so based on what I know, 10k is a good shake down mileage to reach some level of confidence in the build.
John B
Kansas City, Missouri
2024 ford ranger raptor
retired engineer
Lots of good information to consider. You forced me to put my brain to work, and I've got a couple of chemical engineering degrees. Thanks
Glad I could introduce something new that might be of value. I had a ton of questions about it at first as well and was very skeptical until I kept digging and look at the actual testing, sources of that testing and who actually funded the research.
What I like is that it's not an oil additive as it doesn't change the oil's chemistry, it just uses the oil as a carrier to the locations of heat and pressure for form the film over time, very much like ZDDP does, but ZDDP tribo-films collapse very rapidly, they literally only last for seconds and are constantly forming and decaying during operation, so the ZDDP gets used up. It also doesn't really reduce friction either, so its main benefit is controlling wear during boundary layer and mixed mode lubrication regimes.
I had a to learn a lot about some of the mechanisms behind as that's not my core area of expertise! Enjoy.
Satex
Blake
San Antonio
2024 Ranger 2.7 Ecoboost
First, thanks. I viewed the video after reading your posts. The video didn't address wet clutches, but it did show a Kawasaki motorcycle that has a wet clutch.
I posted a comment in the video and asked for clarification, but I thought you might be interested in the implied application vs what you wrote. FWIW, I follow your logic regarding wet clutches, so I'm not pushing back.
Good point, if I recall, that recommendation came from some of the reviews on their site (unless I'm misremembering) where customers asked about it and their tech support said no to wet clutches or 2 cycle applications unless your SUPER CAREFUL about run-in on wet clutches, or you risk forming a semi-permanent lubricious film on the clutch plate / pads due to the heat and pressure since in that application the clutch is the main mode of power transfer unlike a torque converter automatic where the converter handles all of it until lockup and the difference in rotation velocity is usually not more than 2:1 ratio (so very limited slip and loading during normal shifting).
Basically, the dumb smart particles will form on the locations of greatest heat / pressure, so in a torque converter automatic that's going to be on the gears, pumps and bearings mostly unless you're maybe towing or really flogging it. I've yet to see a single person report slip in conventional auto's due to its application and that's been my own experience (115k on one car, applied it back at 30k, then again at 110k to trans, no slip, shifts better than when I got it).
It might be worth reaching out to them to clarify and post back in case I'm wrong. I don't' have any sport bikes or dual clutch cars or even 2 cycle engines, so for me it's moot, but I wanted to make it known just in case.
Satex
Blake
San Antonio
Tganks for the added context.
I did post a question in the comments section of the video. If they don't respond there, I'll probably follow up directly.
I noticed that because I'm a "motorcycle guy." I've had wet clutches that were very sensitive to oils, even when the oil met all required specs.
I'm not dying to try TriboTex in my Aprilia 660 necessarily, but anything motorcycle related always piques my interest.
In lower powered engines, usually the only way to really notice the difference is some gain in fuel economy and smoothness of operation, particularly shift quality of the trans. But that doesn't negate the other benefits, its kind of a whole package kinda thing as how you have look at it.
On a more powerful engine, the difference is more noticeable, it really woke up my GT's 5.0 since that engine had a lot of friction losses being a 32v DOCH with larger displacement. In my little Mazda 3, I do it not so much for power as a few hp isn't going to be noticeable, but the durability and fuel economy benefits are there, especially for cars you pile the mileage on.
I'd imagine a 4x4 truck drive train and the 405 hp 3.0L it would be more noticeable, but I'm not even close to my 10k safety factor yet so just enjoying it as is.
Aircraft examiner
So is it put in with each oil change?
Dutch
The land of the wind chill factor
24 Ranger Raptor
Boy - this sounds just like an infomercial - like someone will earn money by promoting this.
Have you any of the caps that you put on top of the distributer that increases HP?
