In production and window sticker
c5ken
Ken
Michigan,USA
2023 ranger
n/a
so do u think my truck is built sitting somewhere
Bt_okst
Bt_okst
BT
Ok/Colo
So I was able to print my window sticker. The truck was built (I think) on 1/8/24.
No word from Ford regarding build, shipping date etc. So sad.
So what do you think all this indicates?
Is the truck sitting in the lot at MAP, still at the plant, etc???
Will be held until all quality checks have occurred abd the ok to buy has been achieved. This could be a couple more weeks or so.
c5ken
Ken
Michigan,USA
2023 ranger
n/a
I live about 30 miles from MAP. Wish I could go pick it up
Bt_okst
Bt_okst
BT
Ok/Colo
At the bottom of your window sticker under the msrp is a box that should say special order. Under special order should be numbers and letters. At the far right should be your invoice date. That's when they invoiced your dealer for the vehicle. If it's invoiced and your blend date has come and gone, your truck should be built and sitting.
fordtrks4ever
Tim
Perkiomenville, Pa
Isn't it that week. Don't think they're churning out that many a day yet.
My understanding was that is per day as mine is 114 of 117
Bt_okst
Bt_okst
BT
Ok/Colo
My day had just under 2000. I think mine was built during the 2nd shift.
If you look at ranger production numbers, there is no way they do 800 much less 2000 in a day. They only produced 2644 total rangers in January. Has to be a weekly number.
fordtrks4ever
Tim
Perkiomenville, Pa
I see you point but non of us know for sure
DockDog
D K
Olney,Maryland
2018 F 150
Ok since I have nothing better to do let's play how high is your production number. Anyone have a number higher than 631/677? What say you?
BTW I know the truck is manufactured and sitting in a Quality Control Hold, awaiting OKTB.
Bt_okst
Bt_okst
BT
Ok/Colo
Okay after doing some heavy research. The blend # on the left of your upper invoice is your sequence number in regards to rangers that day. I'm 220 so the 220th ranger being built that day.
The 408/843 references your expected position out of everything built on the assembly line that day. They build rangers and Broncos on same line, so the 843 is total number of Broncos and rangers expected built that day. This makes way more sense. But you're right, it is a daily number.
