I can't provide definitive answers but maybe my personal observations can help somewhat.Two questions I can't seem to find answers to. First, what's the factory crossover point for the sub? Second, is the factory setup cutting low frequencies to the door speakers, or are low frequencies going to both doors and sub?
Thanks for the reply. I'm going to give that a try. I can live without low bass for a while if it improves overall SQ.I can't provide definitive answers but maybe my personal observations can help somewhat.
To my ears, the sound improved noticeably when I disconnected the subwoofer. Midrange frequencies became more defined. I'm pretty sure the lows are rolled off on the door speakers.
The factory sub doesn't roll off soon enough, hence the distortion that is added to the mids.
I removed the factory sub yesterday and am currently installing the new sub and amp.
Some people leave the factory sub in place when upgrading. I think that's a mistake, it sounds terrible.
It was your comment some time ago about turning down the base to achieve a better overall sound that lead to my experimenting with disconnecting the sub. That's when I discovered just how bad it was. It's been relegated to the attic in my garage.
What sub are you installing?I can't provide definitive answers but maybe my personal observations can help somewhat.
oh wow. Is it easy to disconnect? I don't plan on adding a new sub. But would be interested in hearing it both ways. Aside from sound, is there any drawback to disconnecting factory sub? Does radio give a warning or cause some kind of error code? Can it damage the amp or original circuits?To my ears, the sound improved noticeably when I disconnected the subwoofer. Midrange frequencies became more defined. I'm pretty sure the lows are rolled off on the door speakers.
Hertz MPS 250 S2 shallow subwoofer and Hertz DIECI POWER DP 1.500 Mono AmpWhat sub are you installing?
Very easy. Just disconnect the harness to the subwoofer.oh wow. Is it easy to disconnect? I don't plan on adding a new sub. But would be interested in hearing it both ways. Aside from sound, is there any drawback to disconnecting factory sub? Does radio give a warning or cause some kind of error code? Can it damage the amp or original circuits?
Thanks!
