F150LEDS.com ranger lights
Falconer
Lee
Utah
2024 Ranger Raptor, 2019 Ranger Lariat FX4, BMW 428xi
That grill moulding part number is: N1WZ*8419*DA.
p22hsgh
Sr. Director
I’m running the original version, Matt is sending me the new version that are more recessed to try out. Great co, customer service is fantastic.
I like the way these lights look, I have purchased them and am wondering how you managed to get the connector end through the opening in the grill? The connector on my light set is too large for the opening, any thoughts would be helpful. Who would have thought the most difficult part for is getting light into the slot Thanks
Hofstetm
Mitch
I'm a little late to the party on this topic. But I just installed the F150LED lights to my RR. I agree you can't go in (drill or mount) from the front if you want the OEM look without damaging the grill. The wire connector diameter (and the light itself for that matter) is just too wide. I inserted my lights from the back of the grill. As mentioned, you can take off the grill (seriously, takes only 10 minutes - see the YT videos) but what I'm not seeing done by others is that the actual top strip you mount the lights into can be removed from the grill. I don't have the part number, but I included a picture of the plastic strip. (BTW, the blue tape was a precaution to not scratch the plastic.) It is attached to the actual grill with 6(?) phillips head screws and are simple to remove. Once unscrewed, the strip of plastic, which runs the full width of the grill but is only about 2 inches high, can be easily detatched from the grill. The part is much easier to work with and if you damage it, can easily (and cheaply) be replaced. The sockets for the lights can be reamed out from the back and you never have to modify the grill from the front and risk damaging the look. This process took me about 3 hours, but only because I'm super careful about this type of work. It really is easy. Good luck!
Wow well done here. Huge props. This is exactly the kind of finesse and detail I was looking for before I dove in to see if it was possible. THANK YOU for doing this, paving the way, showing pictures and even having the part number in case things go sideways. Looks great! I’ll be doing this exact same thing this weekend.
p22hsgh
Sr. Director
Thank you for the help, I will give this a go.
Arsenall11
Maple Valley Wa
Mechanical contractor
Cut the plugs off and used butt connectors.
Jimrfox
James
Laurel Hill, FL
Camaro
Several people on the forum are using them. They weren't designed for the 2024 Ranger Raptor so it's not a perfect fit. The pockets on the grill are tapered so the pockets get thinner towards the back. The light housings are not tapered so the lights don't go in deep enough to fit flush with the pockets, they stick out a little(1st pic). It doesn't look bad but I was determined to make mine flush without hacking up the grill so I tapered the light housings a little on a belt sander (2nd pic).
They still do not fit and are advertised and sold to fit. A lot of money to pay for something you have to modify to make work. They tout the plugs in the ad, and I have seen where people suggest cutting off the plug and use butt connectors.
fordgt
Curious if the folks recommending cutting off the plug and using butt connectors are people who didn’t want to spend $45 for the plug and play harness. Personally, I was a little pissed. I ordered mine and received them. 2 weeks later I installed them a few days later I got an email about the plug and play harness. I would have liked a note in the box saying “hey, we got this coming soon!” I really didn’t like tapping into those wires, they aren’t very stout.
raf1919
Chicago
IT
I ended up cutting the plugs and actually removing black housing around it. It fits and looks good, but sucks to have to mod it.
chasvs
Tampa
2019 Ranger Lariat
That answers that question.
They responded to me that they could be made to fit, but did not elaborate on how.
I had assumed it involved some time spent sanding/shaving them with a Dremel but I don't know where the housing starts and at what point I would damage the light.
I 100% agree, I am not wanting to have to custom shape each one if I can help it.
I would much prefer a clean plug and play product.
You can take the black housing off and see the LED in clear plastic. It trimmed that down not using the black housing and they fit perfectly. If you’re looking for plug and play, don’t buy these. If you are willing to do a little work and get an OEM look fit, get these and get to work!
raf1919
Chicago
IT
This is exactly what i did too. then i used some atv to hold in place looks totally flush and almost oem-ish.
