DirtDad
Joe
La Crescenta, Ca
2014 Ford Ranger 4 x 4 Sport
I have always done my own oil changes on my vehicles, and wanted to continue with my new Ranger, but with the placement of the oil filter, it looked like a difficult task. Well, I had already bought Mobil 1 oil, and a motorcraft filter, so I decided to tackle it.
This is what I used to do it.
Ford Ranger DIY: 2024 Ranger 2.3 ecoboost oil change with pictures and details Oil Change items needed
I had a strap type filter wrench, that attaches to a 3/8 extension and wrech, and it proved to be ideal
Ford Ranger DIY: 2024 Ranger 2.3 ecoboost oil change with pictures and details pic of filter wrench set u
I did not remove the tire, and only had to remove one pin insert from the fender inner skirt
Ford Ranger DIY: 2024 Ranger 2.3 ecoboost oil change with pictures and details only pin removed on fender skirt
I was able to pull back the skirt a little, and reach in and slide the filter wrench over the filter. The fact that the extension is to the side of the wrench, and not the middle, actually helped. You can see how it worked in this picture
Ford Ranger DIY: 2024 Ranger 2.3 ecoboost oil change with pictures and details oil filter wrench on filter
I could only turn the filter maybe 1/4" at a time, and the had to reach in and rotate the strap wrench to the right, and then do it again, I think it was about 5 times, but it was very simple, because I didnt have to remove it, just had to rotate/slide it on the filter. At this point, I removed the wrench, and the filter could be turned by hand.
I had read that the filter oil would drain down a built in funnel, but couldnt see it, without removing the entire inner fender skirt. This would require removing I think 5 insert/pins, and 7 or so small screws. Luckily, the oil leaked out of the filter very slowly, and only a couple of drops landed on the ground before I could see where the funnel emptied. It comes out just behind the front sway bar, and next to the driver side frame rail.
Ford Ranger DIY: 2024 Ranger 2.3 ecoboost oil change with pictures and details Sway bar
Ford Ranger DIY: 2024 Ranger 2.3 ecoboost oil change with pictures and details oil filter drain funnel
Its that little black tube you see in the 2nd picture. If you set your drain pan just behind the sway bar bracket, and centered on the frame rail, it should catch any oil from the filter. I would watch and reposition if required. I had very little oil leak out of the filter as I removed it. The filter came out the same space a the wrench went in thru, up and a little to the left of the original position of the filter. It might be beneficial to spray some cleaner down thru the funnel to keep it clean, maybe next time. I usually run my vehicles up the curb on the side the filter is on, and this allows me enough room to work under the car. This also tilted the truck slightly, and may have been responsible for some of the oil leaking back out of the filter before I removed it. I also put the drain plug at the lowest point. Guess the same could be done with a single ramp on just the drivers side. Maybe it really doesnt matter.
Ford Ranger DIY: 2024 Ranger 2.3 ecoboost oil change with pictures and details truck on curb
I dont have pictures for the oil drain, but its self explanatory. There is a plastic "skid plate" that has to be removed. Its held in place by 6, 15mm bolts. The 3 on the back need to be removed completely, as well as the center one at the front, the 2 at the other ends in the front can just be loosened up, and the plastic "skid plate" slides out. The oil pan is aluminum, and the drain bolt takes the same 15mm socket. The drain plug has a built in silicon washer, that is reusable, so you just re use it. Be careful not to cross thread or over tighten the drain plug, thread it in by hand as much as you can. Remember, the pan is aluminum. The bolts holding the "skid plate" up are pretty stiff to remove, they have a factory loctite on them.
Ford Ranger DIY: 2024 Ranger 2.3 ecoboost oil change with pictures and details funnel in motor
I put in just under 5 1/2 quarts of 5-30 Mobil 1, and will move the truck to a level area to check the level. Now that I have done it once, I think I can do the next oil change in less than 1/2 hour. I was really concerned wether I would be able to remove and replace the oil filter. Specially since Im 70, and not as flexible as I used to be, plus have arthritis in my thumbs, but it was pretty easy. I printed out the instructions on how to reset the oil monitor, and my wife laminated it into a card for me. I will keep this card along with the top of the new filter box, with all the oil change details, date, mileage, next oil change, type of oil, and socked size needed, written on the back of it, in the glove compartment.
Ford Ranger DIY: 2024 Ranger 2.3 ecoboost oil change with pictures and details Instructions on resetting oil monitor
Reset the oil monitor, checked my other fluids (no power steering!), and now Im good for another 7500 miles. Yes, I changed my oil at 7500 miles, and will keep that schedule. Its what I have done in all previous vehicles since switching to Mobil 1 on my 1986 Bronco II. There was 24% oil life left at the time of the oil change.
I hope this helps someone considering doing a DIY oil change.
joecounty2025
joe
texas
2024 ford ranger xl stx 4x4
5 1/2 quarts is all you put in?
thats what i was thinking about doing?
Trimjb
Tennessee
2024 Ranger FX4
Thank you for the photo instruction.
Gives me something to look forward to!
Like you, I also like to do my own maintenance if possible.
Rangerjimm
2025 Ranger Lariat 2.3
Is it not possible to reach that filter from the top? If not I think I will put that side on a jack and remove that wheel to be able to go through the wheel skirt easier.
Rangerjimm
XLTRangerRick
CT
24 Ford Ranger XLT FX4 Velocity Blue
I changed my oil filter from the top just lean over the engine and use a cap filter on a socket wench. Can't remember if I needed a 3" extension or not but it was less than a minute to loosen.
Rangerjimm
Thats good news as I have long arms. I wish I could use an oil extractor so I didnt have to take that shroud off the bottom but someone reported you cant get to the bottom of the pan due to a baffle or something in the pan.
DirtDad
Joe
La Crescenta, Ca
I did end up putting 6 quarts in, its at the middle of the safe area hash marks. Im 5'9", and didnt see how I would reach the filter from the top. Maybe with a step ladder, and kind of laying on the motor? It was pretty easy to do what I did thru the wheel well.. You could take the wheel off, but seems like a lot of extra work when you can reach the filter without removing the wheel. I think next time Ill be able to change the filter in a few minutes.
IndyBrett
Brett
Indiana
2024 Ford Ranger Lariat
EE
I also did my oil filter from the top. The bottom seemed impossible and I really did not want to take the wheel liner out or bend it back. It seems like there are way more fasteners on the 6G liner than on the 5G videos I have seen. Worked just fine from the top. I think I am going to swap out the plastic skid plate under the engine for the one from Rival with the sweet access plate for the drain.
Rangerjimm
Link to that Rival plate please! That sounds perfect!
joecounty2025
joe
texas
can you post a picture of the route from the top?i tried it but didnt seem like enough room for my arm unless i tried in the wrong spot
