2025 Ranger 6G - 4-Wheel Flat Towing behind RVs - YES!
TimmyB
Nokomis, FL
21 Ranger Tremor
Hi folks, just joined the forum. My father purchased a 2025 Ford Ranger and is configuring it to flat tow.
He used to do this with his Toyota Tundra, where he was able to tap into the Tundras break pedal sensor switch(?) And feed that back into an led in RV, for break on detection.
He'd like to do this with the Ranger but is struggling to find this switch. He's found YT videos for the 2024 and location of switch but nothing for 2025.
Anyone have any suggestions?
TIA...
Doesn't his supplemental braking system provide him with this info?
Sonofason
Oregon
Ford ranger
Actually it doesn't, he's wanting to re-use the tow package from Tundra, with new baseplates for Ranger. Supplemental braking system is older than Ranger, so 2025 not included in instructions.
In fact, is there a supplemental braking system in the market for a 2025?
TimmyB
Nokomis, FL
21 Ranger Tremor
His supplemental braking system should have a display unit for the cab of the RV which monitors the braking system while underway. I have a Blue Ox Patriot. The display looks like this:
Ford Ranger 2025 Ranger 6G - 4-Wheel Flat Towing behind RVs - YES! 1743977005799-ah
When brakes are applied at the toad by the Patriot system, it will display this on this screen. Do you know what system he is using?
TimmyB
Nokomis, FL
21 Ranger Tremor
Sonofason
Oregon
Ford ranger
Thanks, sorry I'm not very clear.
Yes, he has that as part of his system.
What he can't figure out is where to attach it on the Ranger.
On his Tundra and on videos for previous years Rangers, that brake signal line is near the firewall and brake pedal.
The wiring on the 2025 Ranger is different and he can't locate the brake system wiring.
TimmyB
Nokomis, FL
21 Ranger Tremor
OK, now I understand. For that stuff, I always let the pros handle the install. Too many things that I can muck up! This might be a tough one simply because you're not going to find too many people who have the 25 and are flat-towing it after the cluster that the 24 MY was. Good luck to you. Hopefully, someone has the answer here!
Sonofason
Oregon
Ford ranger
Thank you. Appreciate your help.
I'm exploring to see if he can just create a pigtail and pull the signal from the rear bumper of Ranger, but will need to check if it's active when being towed.
songkajai
2025 Raptor Marsh Gray
For the lights nothing is officially made yet except a kit to cut the wires.
However after some cross referencing the plugs are the same as a 2022/23 F150, go figure, not a Bronco!
CURT 52103 Custom Towed-Vehicle RV Wiring.
I have the harness and it all fits fine. Will be confirming in the next few days that it actually works without any modes but it should.
Here is the pinout for the Raptor; (c417 connector)
Ford Ranger 2025 Ranger 6G - 4-Wheel Flat Towing behind RVs - YES! Screenshot 2025-01-14 at 3.28.14 PM
Here is the Pinout for the F150;
Ford Ranger 2025 Ranger 6G - 4-Wheel Flat Towing behind RVs - YES! IMG_5086
songkajai
Have this installed now and it works fine.
Did notice that the turn signals work okay.
The driving lights are okay but only the bottom C lights up. Under normal condition, both the bottom and top are driving lights with just the top as driving and blinker.
Not a big deal but looking at the pinout I see why. It should be fixable but don't think it is an issue anyway!
Not only that, don't plan on lots of night driving so the brake and turn is the most important.
Might just turn on the driving lights on the truck anyway for some night driving. That will make the other marker/driving lights work as well. Draw should be very low with them all being LED's.
Using a night Hawk tow bar and that has marker lights as well for night driving.
Waiting on the Base plat now from Blue Ox. It was designed last month but not completed for sale yet.
The part number is;
BX2915 Ford Ranger Raptor (Includes Adaptive Cruise Control, Shutters, & Turbo) Baseplate - Blue Ox
