Stock suspension differences: SR5 vs Off-Road/ORP
Matteblack
TRD Off-Road Premium
PNW
2010 4Runner TE
I understand that the TRD off road and off road premiums come with the red Bilstein's. Do the SR5 models come with them as well? Wondering why the clearance is 1" higher on the Off Road versus SR5 and if its just the tire difference and/or the Bilsteins.
Thanks,
MB
nubbins_
SR5
Well-known member
Thanks,
MB
SR5 is 245/70R17 which is something like 2" smaller tire diameter than 265/70R18 on TRD OR. Which is about 1" difference ground clearance, ignoring other factors
SR5s should have basic unbranded shocks I'm pretty sure. I thought Sport doesn't have proper Bilsteins either, so no reason for SR5 to have them. And any ride height difference from suspension would have to come from springs, not shocks.
jb.aubry
Active member
JB
Quebec City
none
@nubbins_ A bit off topic but I will ask, the TRD Sport model has a somewhat limited tire size: 265/55R20
When you try some online tire stores, you don't get much results for that size.
Would you have any similar size to suggest that would still fit the factory 20 inches rim and the 4Runner 6th gen while not fooling too much the odometer?
nubbins_
SR5
Well-known member
I won't lie, I would just ditch the 20s. imho kinda a nonsense wheel size for something like a 4Runner, you only start getting half decent sidewall height on 20s at like 34"+, which is almost always HD truck territory. 265/70R17 is probably one of the most common tire sizes in history.
iirc a few full size trucks like 275/55R20 as a stock tire size, which works out to be almost a 32" on the dot. It's a pretty minor difference (a "big" (esp. AT/MT in LT size) nominal 31.5" can be as big as 31.7") and F-150 has used that size since as early as 12th gen (2009-2014) I'm pretty sure. OTOH GM and RAM also used that size stock. Should have a good number of tire choices......well, about as much as can be expected for a relatively slim tire on a 20" rim I guess.
theo
TRD Sport Premium
Well-known member
theo
Blk4runner1960
2025 4 runner trd sport premire
I’m going with a 275/60/20 it 33” tall
how wide is the trd sport 20” rim and offset
jb.aubry
Active member
JB
Quebec City
none
Is it me or its a weird choice from Toyota?
Here in Canada, the SR5 is already quite expensive and just to get an heated steering wheel you have to add 5k$ and jump to the next level which is the TRD Sport with that 20" tire size, at least it gives you two more colors to choose from and a few more goodies.
I am still debating going with the base SR5. Decisions! :cool:
nubbins_
SR5
Well-known member
Yeah you're not the only one, TRD Sport is at the bottom of my list. Whole bunch of pointless stuff I absolutely would not pay for (20s that I would ditch immediately even for steelies, big cluster yet small infotainment, fake hood scoop).
SR5 has remained at the top of my list since launch, it's a no-brainer given CAD prices. I don't mind the lack of heated steering wheel but the heated seats are a big plus. Have been following that thread where someone swapped the big infotainment screen into their lower trim Tacoma and aside from working out some wiring connectors it seemed straightforward enough.
I came across some dealer photos of a SR5 Ice Cap with some apparently 265/70R17 (Ridge Grapplers?) on the stock SR5 17" wheel - I must say they look quite decent. Black lug nuts and a classier black or TRD center cap could really complete the look.
2025 Toyota 4runner Stock suspension differences: SR5 vs Off-Road/ORP 2025 4runner sr5 with bigger tires 2
risurfstyle
SR5
Active member
James
New England
2025 SR5
I really like my SR5 and the simplicity - put 265/70r17 Falken Wildpeak SW4s on it - similar to this dealer look, and it makes a big difference in aesthetic but is a little louder and rougher
nubbins_
SR5
Well-known member
Just checked your thread - your SR5 in Underground looks great and exactly what I would go for (would probably opt for Dueler Ascents or Outpost nATs in that size). Not gonna lie, the pics of the Ice Cap one are swaying me a bit in that direction though
jb.aubry
Active member
JB
Quebec City
none
Just for fun and for the curious like me, I changed the stock size of the TRD Sport from 265 to 275/55R20.
Now, plenty of options are offered if you search for the 275 size and you don't lose much on the odometer. I still wonder why Toyota picked the 265 size? Would the 3.77% increase in the tire width would rub at full steering turn?
2025 Toyota 4runner Stock suspension differences: SR5 vs Off-Road/ORP 1742657944607-9y
nubbins_
SR5
Well-known member
Perhaps just trying to eke out any last bit of fuel economy from a narrower tire or lighter weight? Just spitballin'. It does make for nice uniformity through the entire lineup if SR5's 245/70R17 didn't throw a wrench into the works - 265 width on all other trims.
285/70R17 seems to be pretty thoroughly vetted as fitting with no rub, now across both Tacoma and 4Runner. So surely 275/55R20 would not present fitment issues.
Stock SR5 fits 285/70/17 Tires (33's). No lift & no rubbing (photos) | 2025 4Runner Forum (6th Gen) Community - 4Runner6G.com
theo
TRD Sport Premium
Well-known member
theo
Blk4runner1960
It could be a cost factor
theo
TRD Sport Premium
Well-known member
theo
Blk4runner1960
275/55/20 are a waste of money in no more than a 1/2 “ wider,taller,side wall in any direction. Factory will put a certain tire on a vehicle due to court. I didn’t pick the 17” sr5 because of the tire size. Many custom wheels company do fool around with wheels under 20”. Most factory wheels on truck and suv these day are
YWG_YYZ
New member
Winnipeg MB
Golf R Mk8
Since there are at least 3 threads on the topic of suspension, I will post my related question here.
Where I live, it is difficult to find a base SR5 for test drive, and the ones I found are either TRD Sport or TRD Offroad.
As Toyota has a slight different suspension for almost all the trims,
I'm interested to know about on road comfort. Both compliance and handling/rebound.
My understanding is that:
SR5 - "regular" spring and damper
TRD Sport - "sport" tune suspension - is that different springs and damper?
TRD Offroad - Bilstein shock - ?unique spring?
Limited - Adaptive
Do all the passive set up feel significantly different from each other on the road?
Does Sport have higher (than SR5) spring rate/damping rate - ie. bigger initial impact, but with the trade off having less rebound/settles down quicker better?
Bilstein shock, how is it in terms of initial impact/damping (compared to SR5 or OR)?
