- Thread starter
- #1
Has anyone mounted the rear dash cam yet? does the 5th gen mounts work?
Updated with install info & pics by @jaymay82 (from his posts below)
I did the @Wolfbox G900 pro with the rear camera mounted on the exterior just under the liftgate spoiler.
This is the video I watched on how to do the rear camera install on the exterior. Not my video.
Mounted slightly off to the driver-side to be away from the rear wiper, and also slightly towards the rear glass so that there's some coverage from direct sunlight and rain hitting the lens. Unlike the video, I simply used the included double-sided tape for mounting. Eventually I will utilize the screw and locking nut method used in the video.
Removing the spoiler is easy, just open the rear gate and there's 4 round rubber covers with i believe 10mm bolts inside. Remove the 4 bolts and the spoiler lifts up enough (don't have to remove it like the 5th gen video) to run the cable and follow the video instructions on running it through the existing cable bundles and into the cabin.
