Question For Those That Have An Aftermarket IC
Blue_Raptor
Simi Valley, CA
For anyone with an aftermarket IC: did you happen to pay attention to the charge air temps before and after swapping the IC?
With the stock, I’m seeing anywhere between 20-60 deg over ambient, even tonight with temps in the high 40’s.
Im curious if this is really just the stock IC, or more to do with the active shutters and not much air actually passing through the IC.
On my fiesta ST, I had a CPe IC which kept charge temps within 10 deg of ambient.
Mad_Motorhead
Chad
SC
I have the Wagner Tuning intercooler and
It's way lower than what stock was, And it recovers much faster.
Quick
Stamford, CT
24 Ranger Raptor
I have the Cobb IC. Have noticed charge temps are generally 10-12 degrees higher than ambient, when ambient is ~20-30 degrees. This is when running at 75mph with 35s with factory gearing.
Blue_Raptor
Blue_Raptor
Simi Valley, CA
Ah interesting, thank you both. The quicker recovery is what I would expect as generally heat soak is the biggest with the stock ICs but the fact you do get much lower charge temps is good and seems to make an aftermarket IC definitely worth it.
