J-braces required for 2024 only?
turtlespeed7
Gregory
Washington/Hawaii
2023 2 dr Bronco Basesquatch/2025 Ranger Raptor
Is it true 2025 Ranger Raptor no longer needs J-braces, but 2024s still do if you want to carry weight above the bed? Did Ford fix that issue for 2025 builds?
Yes anything built after Sept 2024. Not sure of the day think it was 17th.
Aircraft examiner
you have to lay under the truck bed, in front of hte rear tires and look up into the darkness. check that thread linked in an earlier post and there should be pictures of what to look for when you are down there.
