tmuecke
- Thread starter
- #1
Hello, I have a Ranger Wildtrak X. Ford says in the Specs that the over all length is 5374mm with tow receiver and the height is 1884mm. I have measured mine and I get 5542 mm with towbar and a height of 1847 (roof), 1876 (roof rails) and 2047 mm (Antenna). As not all Rangers have a towbar or roof rails, where do Ford Specs refer to? Does the higher ground clearance of the Wildtrak X not affect anyhow the over all height? All given heights for the Double Cab are the same! Thanks for any explanation.
