RollingRocker
TRD Off-Road
Well-known member
Clay
Wyoming
2025 Toyota 4Runner Off-Road, 2021 Toyota Highlander Platinum
Update: STL file added for download:
https://www.4runner6g.com/forum/att....13221/?hash=271aad3d31c914d048f25eb42f337651
I found a suitable location in the engine compartment to mount my ARB Single Motor Air Compressor just didn't have a good way to mount it. The local maker's space at the college has an incredible 3D printing lab so I decided to model something myself. I feel like it turned out decent for my first foray into 3D printing. I started out on solid works but jumped over to Shapr3D as solid works is just not that intuitive.
2025 Toyota 4runner 3D Printed Bracket For ARB Single Air Compressor - Underhood Mount [STL File Attached] Image 4-24-25 at 11.23 PM
2025 Toyota 4runner 3D Printed Bracket For ARB Single Air Compressor - Underhood Mount [STL File Attached] IMG_2327
2025 Toyota 4runner 3D Printed Bracket For ARB Single Air Compressor - Underhood Mount [STL File Attached] IMG_2328
2025 Toyota 4runner 3D Printed Bracket For ARB Single Air Compressor - Underhood Mount [STL File Attached] IMG_2330
2025 Toyota 4runner 3D Printed Bracket For ARB Single Air Compressor - Underhood Mount [STL File Attached] IMG_2325
2025 Toyota 4runner 3D Printed Bracket For ARB Single Air Compressor - Underhood Mount [STL File Attached] IMG_2333
2025 Toyota 4runner 3D Printed Bracket For ARB Single Air Compressor - Underhood Mount [STL File Attached] IMG_2335
2025 Toyota 4runner 3D Printed Bracket For ARB Single Air Compressor - Underhood Mount [STL File Attached] IMG_2336
2025 Toyota 4runner 3D Printed Bracket For ARB Single Air Compressor - Underhood Mount [STL File Attached] IMG_2337
Keroppi
TRD Off-Road Premium
Well-known member
Mark
Hawaii
Incoming 2025 4Runner TRD ORP
Love the ingenuity and great job for your first 3D print. Can you share the .STL file?
RollingRocker
RollingRocker
TRD Off-Road
Well-known member
Clay
Wyoming
Absolutely. I’m making a couple small revisions before we print it on the industrial level printer today. Once it successfully prints I will share the STL file.
Obs
SR5
New member
OK
25 SR5
What material are you printing it with? I'd be concerned about the plastic deforming.
RollingRocker
RollingRocker
TRD Off-Road
Well-known member
Clay
Wyoming
Piece looks great, but. Compressors make heat + under hood heat.
I considered the engine bay heat and possible issues with print failing so the final print will be made on an industrial grade printer. It can use filament that can take the heat. The college uses this for diesel engine parts designed in the machine tool technician and diesel mechanic programs so it can withstand the engine compartment heat without issues.
RollingRocker
RollingRocker
TRD Off-Road
Well-known member
Clay
Wyoming
I will get the exact type of material used today and let you know. The guy that runs the lab said we would have to use the industrial printer to make it strong enough to survive the stresses of the engine bay.
RollingRocker
RollingRocker
TRD Off-Road
Well-known member
Clay
Wyoming
Excellent work my friend. a good clean print too.
Thank you! It's nice to have access to a higher end printer as well call on the expertise of the guy that runs the maker's space. He has been a huge help.
RollingRocker
RollingRocker
TRD Off-Road
Well-known member
Clay
Wyoming
Final print is underway. The filament is ABS + which can withstand temperatures up to 100 Celsius or 212 Fahrenheit before it would begin to deform. It should more than handle the engine bay on even the hottest days. I will figure out a way to share the STL file so if anyone wants to print one they can.
Cityzen10
Well-known member
Ryan
Gresham OR
2014 Tundra SR5, 2006 4R Sport, 2025 4R Off-Road Premium
Man, now you have me going down the compressor rabbit hole. Looks like that compressor is about $350 for the kit (if I'm looking at the right one on ARB website). And I can make a mount for that spot easy enough. I don't have access to that good of a 3D printer but I have a plasma table and a press brake so I can make one out of formed steel plate no problem. :unsure:
