2024 Ranger Raptor Oil Life Reset Procedure
Baja1k
Andy
Wisconsin
2024 Ranger Raptor, 2024 Triumph Street Triple
John Deere Spark Plug Peddler
Hi everyone, I will be doing my first oil change in a few days, and was just curious of what the procedure is to reset the oil life? I am coming from a Focus ST where you had to hold the brake and throttle pedal with the accessory power on, and engine not running. I haven't been able to find anything online thus far, aside from the oil change procedure. Full disclosure, I haven't tried to battle with the manual in the truck to find it. If only I had a paper manual haha!
T-Rev
Engine Oil - Resetting the Intelligent Oil Life Monitor (fordservicecontent.com)
RESETTING THE INTELLIGENT OIL LIFE MONITOR
Only reset the oil life monitoring system after changing the engine oil and oil filter.
  1. Press the menu button on the steering wheel to enter the instrument cluster display main menu.
  1. Select Vehicle Maintenance.
  1. Select Oil Life.
  1. Press and hold the OK button until the system reset confirmation appears.
Baja1k
Baja1k
Andy
Wisconsin
  2. Select Vehicle Maintenance.
  3. Select Oil Life.
  4. Press and hold the OK button until the system reset confirmation appears.
Well that is way too easy... just like resetting the trip measurement then. Thanks T-Rev!
Ag3ntC00p3r
Wisconsin
Product Manager
The gas/brake pedal hold is to turn over the engine without ignition to prevent dry start after oil change. I would still do that on first startup.
The oil life reset is as described above.
John B
Kansas City, Missouri
2024 ford ranger raptor
retired engineer
This is a nice oil change video posted on here by a member
